    How to test duex.pwm5
    Firmware installation
    566
    • trobisonundefined
      trobison
      I have decided to start a new thread on my issues. My original query was in Feb. I was experiencing network dropouts. I upgraded to version 3.4 in hopes of removing the dropouts. However, they persisted. I removed anything that could be picking up interference that was non-essential to printing. This included the screen. I found that with the screen removed, the network issues are almost non-existent.
      The more pressing issue, I seem to have two servo ports that are not working. For many months before the update, I was using "duex.pwm5" to clean nozzles and the toolchange selected a new extruder. When I reconnected the servo, it no longer worked. I tried “duex.pwm4” and that did not drive a stepper either. But “duex.pwm3” worked. At this point I swapped to a hobby 9G servo for testing to simply as much as possible. I get the same results.
      This servo can be driven on “duex.pwm3” but not “duex.pwm4” or “duex.pwm5”. How can I test these ports?
      To exercise the servo connected to duex.pwm3 I use:
      ;Exercise Servo
      M280 P0 S180		; Set Servo Position for Wipe to 160 degrees
      G4 P600			; Pause 600 ms
      M280 P0 S1-0		; Set Servo Position for Wipe to 0 degrees
      M280 P0 S180		; Return to Servo Position for Wipe
      Other interesting behaviour since upgrading to Version 3.4. Sending a M122 causes the network to drop out and then return. I didn’t get this Version 3.3. Is this new and normal?
      Current working config.
      ; generated by RepRapFirmware Configuration Tool v3.3.5 on Sat Nov 13 2021 18:20:50 GMT+1100 (Australian Eastern Daylight Time)
      M111 S0 						; Debugging off
      G21 							; Work in millimetres
      M575 P1 S1 B57600        ; enable support for PanelDue
      ;M575 P1 S1 B115200
      G90        ; send absolute coordinates...
      M83        ; ...but relative extruder moves
      M550 P"ToolChanger"        ; set printer name
      M669 K1        ; select CoreXY mode
      M552 S1 P192.168.10.60			; enable network and set IP address
      M553 P255.255.255.0             ; set netmask
      M554 P192.168.10.1              ; set gateway
      M586 P0 S1 						; Enable HTTP
      M586 P1 S0 						; Disable FTP
      M586 P2 S1 T0					; Enable Telner
      M569 P0 S0        ; X physical drive 0 goes forwards
      M569 P1 S0        ; Y physical drive 1 goes forwards
      M569 P2 S1        ; Z physical drive 2 goes backwards
      M569 P3 S1        ; E0 physical drive 3 goes backwards
      M569 P4 S1        ; E1 physical drive 4 goes backwards
      M569 P5 S1        ; E2 physical drive 5 goes backwards
      M569 P6 S1        ; E3 physical drive 6 goes backwards
      M569 P7 S0        ; Coupler physical drive 7 goes forwards
      M569 P8 S0        ; Unused - physical drive 8 goes forwards
      M569 P9 S0        ; Unused - physical drive 9 goes forwards
      M584 X0 Y1 Z2 C7 E3:4:5:6        ; set drive mapping
      M350 X16 Y16 Z16 E16:16:16:16 I1                                            		            ; configure microstepping with interpolation
      M350 C16 I10 																					; Configure microstepping without interpolation
      M92  X100 Y100 Z800 C91.022 E395:395:395:395 									   				; set steps per mm
      M566 X900 Y900 Z8 C2 E800:800:800:800             												; set maximum instantaneous speed changes (mm/min) - Jerk Settings
      M203 X35000 Y35000 Z1200 C5000 E5000:5000:5000:5000												; set maximum speeds (mm/min)
      M201 X6000 Y6000 Z400 C500 E3000:3000:3000:3000						  				            ; set accelerations (mm/s^2)
      M906 X1800 Y1800 Z1330 I30									   								   ; Idle motion motors to 30%
      M906 E1000:1000:1000:1000 C500 I10     			 											   ; Idle extruder motors to 10%
      M84 S30        ; Set idle timeout
      M208 X-10 Y-7 Z0 S1        ; set axis minima
      M208 X350 Y275 Z300 S0        ; set axis maxima
      M208 C-45:360
      M574 X1 Y1 S3 																					; Set X / Y endstop stall detection
      M574 C0 Z0  																					; No C Z endstop
      ; Z probe
      M558 P8 C"zstop" H3 F360 I0 T20000 																; Set Z probe type to switch, the axes for which it is used and the dive height + speeds
      G31 P200 X0 Y0 Z0	 																			; Set Z probe trigger value, offset and trigger height
      M557 X30:333 Y50:249 S40																		; Set probing points
      M308 S0 P"bedtemp" Y"thermistor" A"Bed" T100000 B4138                                          ; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bedheat" T0 q10        ; create bed heater output on bedheat and map it to sensor 0
      M307 H0 B0 S1.00        ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0        ; map heated bed to heater 0
      M143 H0 S200        ; set temperature limit for heater 0 to 200C
      M308 S1 P"e0temp" Y"thermistor" A"T0" T100000 B4725 C7.06e-8                                         ; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e0heat" T1        ; create nozzle heater output on e0heat and map it to sensor 1
      M307 H1 B0 S1.00        ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S300        ; set temperature limit for heater 1 to 300C
      M308 S2 P"e1temp" Y"thermistor" A"T1" T100000 B4725 C7.06e-8                                         ; configure sensor 2 as thermistor on pin e1temp
      M950 H2 C"e1heat" T2        ; create nozzle heater output on e1heat and map it to sensor 2
      M307 H2 B0 S1.00        ; disable bang-bang mode for heater  and set PWM limit
      M143 H2 S300        ; set temperature limit for heater 2 to 300C
      M308 S3 P"duex.e2temp" Y"thermistor" A"T2" T100000 B4725 C7.06e-8                                    ; configure sensor 3 as thermistor on pin duex.e2temp
      M950 H3 C"duex.e2heat" T3        ; create nozzle heater output on duex.e2heat and map it to sensor 3
      M307 H3 B0 S1.00        ; disable bang-bang mode for heater  and set PWM limit
      M143 H3 S300        ; set temperature limit for heater 3 to 300C
      M308 S4 P"duex.e3temp" Y"thermistor" A"T3" T100000 B4725 C7.06e-8                                    ; configure sensor 4 as thermistor on pin duex.e3temp
      M950 H4 C"duex.e3heat" T4        ; create nozzle heater output on duex.e3heat and map it to sensor 4
      M307 H4 B0 S1.00        ; disable bang-bang mode for heater  and set PWM limit
      M143 H4 S300        ; set temperature limit for heater 4 to 300C
      M950 F0 C"fan0" Q0        ; create fan 0 on pin fan0 and set its frequency - Fan Not used
      M106 P0 S0 H-1        ; set fan 0 value. Thermostatic control is turned off - Fan not used
      M950 F1 C"fan1" Q500        ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H1 T70        ; set fan 1 value. Thermostatic control is turned on
      M950 F2 C"fan2" Q0        ; create fan 2 on pin fan2 and set its frequency
      M106 P2 S0 H-1        ; set fan 2 value. Thermostatic control is turned off
      M950 F3 C"duex.fan3" Q500        ; create fan 3 on pin duex.fan3 and set its frequency
      M106 P3 S1 H2 T70        ; set fan 3 value. Thermostatic control is turned on
      M950 F4 C"duex.fan4" Q0        ; create fan 4 on pin duex.fan4 and set its frequency
      M106 P4 S0 H-1        ; set fan 4 value. Thermostatic control is turned off
      M950 F5 C"duex.fan5" Q500        ; create fan 5 on pin duex.fan5 and set its frequency
      M106 P5 S1 H3 T70        ; set fan 5 value. Thermostatic control is turned on
      M950 F6 C"duex.fan6" Q0        ; create fan 6 on pin duex.fan6 and set its frequency
      M106 P6 S0 H-1        ; set fan 6 value. Thermostatic control is turned off
      M950 F7 C"duex.fan7" Q500        ; create fan 7 on pin duex.fan7 and set its frequency
      M106 P7 S1 H4 T70        ; set fan 7 value. Thermostatic control is turned on
      M950 F8 C"duex.fan8" Q0        ; create fan 8 on pin duex.fan8 and set its frequency
      M106 P8 S0 H-1        ; set fan 8 value. Thermostatic control is turned off
      M563 P0 S"T0" D0 H1 F2        ; define tool 0
      G10 P0 X0 Y0 Z0        ; set tool 0 axis offsets
      G10 P0 R0 S0        ; set initial tool 0 active and standby temperatures to 0C
      M563 P1 S"T1" D1 H2 F4        ; define tool 1
      G10 P1 X0 Y0 Z0        ; set tool 1 axis offsets
      G10 P1 R0 S0        ; set initial tool 1 active and standby temperatures to 0C
      M563 P2 S"T2" D2 H3 F6        ; define tool 2
      G10 P2 X0 Y0 Z0        ; set tool 2 axis offsets
      G10 P2 R0 S0        ; set initial tool 2 active and standby temperatures to 0C
      M563 P3 S"T3" D3 H4 F8        ; define tool 3
      G10 P3 X0 Y0 Z0        ; set tool 3 axis offsets
      G10 P3 R0 S0        ; set initial tool 3 active and standby temperatures to 0C
      ;tool offsets
      ; !ESTIMATED! offsets for:
      ; Hemera-tool: X20 Y43.5 Z-6
      ; G10 P0 X-0.10 Y-1.0 Z-7   -  Use this as initial starting point for leveling nozzle heights to avoid crashing nozzles into bed
      ; Tool Offsets
      G10 P0 X-0.00 Y0.00 Z-5.31			; Tool 0
      G10 P1 X-0.32 Y-0.76 Z-5.40			; Tool 1
      G10 P2 X-0.20 Y-0.98 Z-5.42			; Tool 2
      G10 P3 X-0.32 Y-0.96 Z-5.53			; Tool 3
      ; Pressure advance was turned off by default.
      M572 D0 S0.020 					; pressure advance T0 Hemera
      M572 D1 S0.020						; pressure advance T1
      M572 D2 S0.020						; pressure advance T2
      M572 D3 S0.020 					; pressure advance T3
      ; Custom settings
      ;Safty Switches
      M950  J0 C"!^e0stop" 				; NC Microswitch - In use on Tool Grabber
      ;M950  J1 C"!^e1stop" 				; NO Microswitch Attached yet (Free)
      ;Duet 2 WiFi and Ethernet: Use this command to tell RRF about the accelerometer:
      ;M955 P0 C"spi.cs4+spi.cs3"
      M593 P"zvd" F42.5  					; use ZVD input shaping to cancel ringing at
      ;M593 P"none"        				; disable input shaping
      ; Pebble Wiper Config
      M950 S2 C"duex.pwm5"				; Port 2
      M950 S1 C"duex.pwm4"				; Port 1
      M950 S0 C"duex.pwm3"				; Port 0
      M501                                ; load saved parameters from non-volatile memory
      M98 P"config.g"
      HTTP is enabled on port 80
      FTP is disabled
      TELNET is enabled on port 23
      Warning: Heater 0 predicted maximum temperature at full power is 551°C
      Warning: Heater 1 predicted maximum temperature at full power is 495°C
      Warning: Heater 2 predicted maximum temperature at full power is 470°C
      Warning: Heater 4 predicted maximum temperature at full power is 542°C
      fcwiltundefined dc42undefined 2 Replies Last reply Reply Quote 0
      • fcwiltundefined
        fcwilt @trobison
        @trobison
        I have found an oscilloscope an essential tool when working with most any sort of electronics.
        Even a cheap "tablet" one from Amazon can be very useful.
          dc42 administrators @trobison
          @trobison said in How to test duex.pwm5:
          No, that's not intentional. Does the M122 command return a full report?
          Please verify that you are running the 3.4.0 final release. There was a bug with driving servos in some of the 3.4 beta and RC versions.
          trobisonundefined 1 Reply Last reply Reply Quote 0
          • trobisonundefined
            trobison @dc42
            @dc42 Sorry, I though I had the output of M122. Here is the output from the console when I powered up the printer, then sent a M122 from the console. Midway down you can see the network drop out after M122 has been sent, then the results from M122. I believe it is running version 3.4.0.
            07/04/2022, 22:31:37	=== Diagnostics ===
            RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0 (2022-03-15 18:58:31) running on Duet Ethernet 1.02 or later + DueX5
            Board ID: 0JD0M-9P6M2-NWNS0-7J9DJ-3SJ6S-K90RJ
            Used output buffers: 2 of 24 (19 max)
            Static ram: 23868
            Dynamic ram: 73160 of which 0 recycled
            Never used RAM 14788, free system stack 118 words
            Tasks: NETWORK(ready,23.8%,226) HEAT(notifyWait,0.1%,332) Move(notifyWait,0.0%,285) DUEX(notifyWait,0.0%,24) MAIN(running,75.1%,440) IDLE(ready,1.0%,30), total 100.0%
            Owned mutexes:
            Last reset 00:01:13 ago, cause: power up
            Last software reset at 2022-04-07 16:44, reason: User, GCodes spinning, available RAM 15260, slot 1
            Error status: 0x00
            Aux0 errors 0,0,0
            Step timer max interval 0
            MCU temperature: min 17.5, current 22.2, max 22.4
            Supply voltage: min 24.0, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
            Events: 0 queued, 0 completed
            Driver 0: standstill, SG min 0
            Driver 1: standstill, SG min 0
            Driver 2: standstill, SG min 0
            Driver 3: standstill, SG min n/a
            Driver 4: standstill, SG min n/a
            Driver 5: standstill, SG min n/a
            Driver 6: standstill, SG min n/a
            Driver 7: standstill, SG min 0
            Driver 8: standstill, SG min n/a
            Driver 9: standstill, SG min n/a
            Driver 10:
            Driver 11:
            Date/time: 2022-04-07 22:31:33
            Cache data hit count 2629899681
            Slowest loop: 6.55ms; fastest: 0.16ms
            === Storage ===
            Free file entries: 10
            SD card longest read time 4.4ms, write time 0.0ms, max retries 0
            DMs created 83, segments created 11, maxWait 44815ms, bed compensation in use: mesh, comp offset 0.000
            === MainDDARing ===
            Scheduled moves 20, completed 20, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
            === AuxDDARing ===
            Segments left: 0
            Movement lock held by null
            HTTP is idle in state(s) 0
            Telnet is idle in state(s) 0
            File is idle in state(s) 0
            USB is idle in state(s) 0
            Aux is idle in state(s) 0
            Trigger is idle in state(s) 0
            Queue is idle in state(s) 0
            LCD is idle in state(s) 0
            Daemon is idle in state(s) 0
            Code queue is empty
            === DueX ===
            Read count 1, 0.82 reads/min
            === Network ===
            Slowest loop: 23.75ms; fastest: 0.02ms
            HTTP sessions: 2 of 8
            Interface state active, link 100Mbps full duplex
            07/04/2022, 22:31:36	Connection established
            07/04/2022, 22:31:36	Connection interrupted, attempting to reconnect...
            Operation failed (Reason: Service Unavailable)
            07/04/2022, 22:31:34	M122
            Static ram: 23868
            Owned mutexes:
            Error status: 0x00
            Aux0 errors 0,0,0
            Driver 10:
            Driver 11:
            === Storage ===
            === MainDDARing ===
            === AuxDDARing ===
            Segments left: 0
            Code queue is empty
            === DueX ===
            === Network ===
            07/04/2022, 22:30:54	Connected to 192.168.10.60
              I can't remember from your previous thread, but did you downgrade to 3.3 and see if it works correctly again?
              • trobisonundefined
                trobison @Phaedrux
                @phaedrux Yes. The same issue. I was asked to send my details to the warranty team. Thank you for following up.
                Regards,
                  @trobison we now have another report of a user not able to operate a BLTouch connected to duex.pwm5. So there may be a bug in firmware 3.4. I will test it on Monday.
                    Phaedrux Moderator @dc42
                    @dc42 said in How to test duex.pwm5:
                    In their case with the troodon board it is now working correctly, so seemingly not related.
                      @trobison I have now tested a BLTouch connected to duex.pwm5 and to duex.pwm4. In both cases it is working correctly, using commands M3280 P0 S10 and M280 P0 S90.
                      • trobisonundefined
                        trobison
                        Cheers guys. I installed a replacement Duex5 board. All working nicely now. I have a question. Is there firmware I have to worry about on the extension board, or is it just that, an extension to the DUET 2 board and firmware is installed there.
                          @trobison there is no firmware on the DueX expansion board.
                          • trobisonundefined
                            trobison @dc42
                            @dc42 Many thanks.
