Is there a terminal like YAT for RPI?
Same config and settings as before update.
M563 P1 D0 H1 F0 ; P1 = tool1 D0 = ext drive H1 = heater1 F1 = fan1
G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets
G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C; Custom settings are not defined
T1 ; select first tool -
2022-05-03 14:45:45 Error: Response timeout: CAN addr 121, req type 6049, RID=26
2022-05-03 14:45:40 M98 P"config.g"
HTTP is enabled on port 80
FTP is enabled on port 21
TELNET is enabled on port 23 -
Email sent for warranty exchange
@tecno please verify that you are using firmware 3.4.0 or 3.4.1 on the main board and on all tool/expansion boards. The CAN protocols change between major firmware versions, so incompatible firmware may be the reason for problems such as the hot end heater not working.
Good Morningm122
RepRapFirmware for Duet 3 Mini 5+ version 3.4.0beta3 (2021-08-24 14:08:24) running on Duet 3 Mini5plus WiFi (standalone mode)
Board ID: 0SBLN-A396U-D65J0-40KMQ-2R03Z-RQHV7m122 b121
Diagnostics for board 121:
Duet TOOL1LC rev 1.1 or later firmware version 3.4.0 (2022-03-15 09:00:04)
Bootloader ID: SAMC21 bootloader version 2.4 (2021-12-10)Cheers
Bengt -
@tecno Better upgrade the mainboard to 3.4.0 final or 3.4.1-rc1.
@chrishamm
Latest rc1 did the trick THANK YOU! -
undefined dc42 marked this topic as a question
undefined dc42 has marked this topic as solved
