    Solved Gcode from Carbide Create
    Gcode meta commands
    • YYCSparks
      YYCSparks last edited by YYCSparks
      Hey guys,
      I havn't tried yet but I wanted to check with Carbide Create will GCode from that app work with Duet firmware 3.x?
      I thought there was an issue due to Carbide not including G1 in front of move commands but then I was reading and it looked like that might have been fixed in a newer version of Firmware.
      Sample:
      G90
      G21
      (Contour.T...)
      M05
      M0 ;T102
      M03S10000
      G0X-110.591Y45.500Z5.000
      G1Z-0.300F203.2
      X-110.585Y46.031F508.0
      X-110.564Y46.560
      X-110.531Y47.084
      X-110.485Y47.605
      X-110.426Y48.123
      I found this in a previous post so it looks like the G1 requirement is not always needed in CNC mode:
      From @dc42
      No. Duet doesn't support "sticky" G1 or G0. You will need to select a different post processor, or modify that one.
      Yes it does, when in CNC mode and using recent firmware versions (2.05 or 3.x).
      I am running 3.4 firmware and have set CNC mode but if I try to run the CNC sample file above I get:
      File 0:/gcodes/Test Carbide Gcode.nc selected for printing
      Finished printing file 0:/gcodes/Test Carbide Gcode.nc, print time was 0h 0m
      oliof 1 Reply Last reply Reply Quote 0
      • oliof
        oliof @YYCSparks last edited by
        @yycsparks The M0 command in line 5 has a specific meaning in RepRapFirmware,Unconditional Stop. So you would need to make sure that is not being emitted.
        <>Creality CR-20 IDEX Duet3 mini 5+<>RatRig V-Minion SKR RRF 1.1<>
        • YYCSparks
          @oliof Oh interesting, thank you for pointing that out. That makes alot of sense now. I will make that change and see if that helps.
          YYCSparks 1 Reply Last reply Reply Quote 0
          • YYCSparks
            YYCSparks @YYCSparks last edited by
            @oliof Thank you very much for your advise it worked great.
            • Topic has been marked as a question  dc42 dc42
            • Topic has been marked as solved  dc42 dc42
