Solved Problem with upgrade from 3.2.2 to 3.4.0
I have a MB6HC with a SBC-Rasbarry Pi 4.
I am using the apt-get update / apt-get upgrade. It says that nothing to upgrade. But when I try the M115 command it says firmware 3.2.2
Do I do something wrong?
I have been following the documentation.
Is there a problem with having a 1XD connected at the sametime you do the upgrade? It looked as if it would do both but did none.
@schickfus can you post an output of M122
no issues with having the boards connected etc -
I think I solved it. I forced the upgrade with a terminal window with the /opt/dfs/bin/DuetControlServer -u
Then I flashed the SD card. Now everything is up and running with 3.4.0
Phaedrux
Phaedrux
