Solved SD card gets full after printing through DWC
I have encountered some problems regarding SD card.
I use 6HC board with SBC.After some printing through Duet web control I always end up with full SD card and I'm not able to find out where to delete cache or any other leftover files. How should I solve this situation? Last time I totally reformatted SD card as I thought there may be more problems related to that but unfortunately all the reinstallation work didn't help and now I have the same problem on my other printer.
I have tried "sudo apt-get clean", then open the SD card manually but I couldn't find where the storage is full.
DF -h command provides me with this information:
Filesystem Size Used Avail Use% Mounted on /dev/root 15G 14G 0 100% / devtmpfs 430M 0 430M 0% /dev tmpfs 462M 16M 447M 4% /dev/shm tmpfs 462M 6.4M 456M 2% /run tmpfs 5.0M 4.0K 5.0M 1% /run/lock tmpfs 462M 0 462M 0% /sys/fs/cgroup /dev/mmcblk0p1 247M 60M 187M 25% /boot tmpfs 93M 8.0K 93M 1% /run/user/1000
I am not able to reach /dev/root folder
M122 diagnostic:
M122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.4.0 (2022-03-15 18:57:24) running on Duet 3 MB6HC v1.01 or later (SBC mode) Board ID: 08DJM-9P63L-DJMSS-6J9F0-3SD6K-9UDB9 Used output buffers: 1 of 40 (26 max) === RTOS === Static ram: 151000 Dynamic ram: 67132 of which 16 recycled Never used RAM 129284, free system stack 132 words Tasks: SBC(resourceWait:,0.7%,436) HEAT(notifyWait,0.1%,321) Move(notifyWait,0.5%,237) CanReceiv(notifyWait,0.0%,772) CanSender(notifyWait,0.0%,348) CanClock(delaying,0.0%,339) TMC(notifyWait,8.0%,92) MAIN(running,90.7%,923) IDLE(ready,0.0%,30), total 100.0% Owned mutexes: HTTP(MAIN) === Platform === Last reset 03:44:58 ago, cause: power up Last software reset at 2022-04-06 00:34, reason: User, GCodes spinning, available RAM 129380, slot 2 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a Error status: 0x00 Step timer max interval 973 MCU temperature: min 25.7, current 26.2, max 26.6 Supply voltage: min 23.3, current 23.6, max 23.8, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 1.0, current 12.1, max 12.5, under voltage events: 1 Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/114/114, gc cycles 0 Events: 0 queued, 0 completed Driver 0: standstill, SG min 0, mspos 8, reads 54347, writes 11 timeouts 0 Driver 1: standstill, SG min 0, mspos 8, reads 54347, writes 11 timeouts 0 Driver 2: standstill, SG min 0, mspos 8, reads 54346, writes 11 timeouts 0 Driver 3: standstill, SG min 0, mspos 8, reads 54346, writes 11 timeouts 0 Driver 4: standstill, SG min 0, mspos 8, reads 54346, writes 11 timeouts 0 Driver 5: standstill, SG min 0, mspos 8, reads 54346, writes 11 timeouts 0 Date/time: 2022-04-11 04:34:46 Slowest loop: 25.88ms; fastest: 0.04ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 125, segments created 16, maxWait 363050ms, bed compensation in use: mesh, comp offset 0.000 === MainDDARing === Scheduled moves 7758, completed 7758, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 13], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 4 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 === GCodes === Segments left: 0 Movement lock held by null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File* is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue* is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty === CAN === Messages queued 67742, received 210444, lost 0, boc 0 Longest wait 0ms for reply type 0, peak Tx sync delay 282, free buffers 50 (min 35), ts 21921/21921/0 Tx timeouts 0,0,0,0,0,0 === SBC interface === Transfer state: 4, failed transfers: 0, checksum errors: 0 RX/TX seq numbers: 6356/6356 SPI underruns 0, overruns 0 State: 5, disconnects: 0, timeouts: 0, IAP RAM available 0x2b880 Buffer RX/TX: 0/0-0, open files: 0 === Duet Control Server === Duet Control Server v3.4.0 Code buffer space: 4096 Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 2 Full transfers per second: 39.35, max time between full transfers: 87.9ms, max pin wait times: 70.0ms/17.6ms Codes per second: 1.34 Maximum length of RX/TX data transfers: 6504/1664
M39 sd card diagnostic:
M39 SD card in slot 0: capacity 15.00Gb, partition size 15.00Gb,free space 0.00Gb, speed MBytes/sec
I was unable to find clear instructions on how and where all the files/cache is stored and how to reach that and clean.
In general DWC settings I have options for storing settings and files in local storage. How there settings behave when turned on?
Thank you very much
Do you have logging enabled?
Do you have a larger SD card to use?
Either way, I would suggest trying a fresh download of DuetPi and re-imaging the card after backing up your config. See how much space is left available on a fresh install. How large are the gcode files you are printing? There may not be much space left over with 16gb to start with.
@ping It sounds very much like you still have the DCS log level set to
debug
(checklogLevel
in/opt/dsf/conf/config.json
) and thatrsyslog
is still running on your image. I strongly suggest disabling it (sudo systemctl stop rsyslog && sudo systemctl disable rsyslog
) and cleaning up the logs (sudo rm /var/log/*.log
). That should free up your SD card again. -
@Phaedrux I have checked if I have logging enabled by @chrishamm method but found out that it is not enabled:
GNU nano 3.2 /opt/dsf/conf/config.json { "AutoUpdateFirmware": true, "PluginSupport": true, "RootPluginSupport": false, "PluginsFilename": "/opt/dsf/conf/plugins.txt", "LogLevel": "info", "SocketDirectory": "/run/dsf", "SocketFile": "dcs.sock", "StartErrorFile": "/run/dsf/dcs.err", "Backlog": 4, "SocketPollInterval": 2000, "BaseDirectory": "/opt/dsf/sd", "PluginDirectory": "/opt/dsf/plugins", "NoTerminateOnReset": false, "HostUpdateInterval": 4000, "MaxMessageAge": 60, "SpiDevice": "/dev/spidev0.0", "SpiBufferSize": 8192, "SpiTransferMode": 0,
Gcode files for printing are usually not so big ranging from 2 to 10Mb.
To be honest I wouldn't want to re-image the card as it may lead to more problem solving the same way like when I reformatted the card for another printer. I have used 32 Gb card for another printer.
Fresh install and maximum one week of use gives usage of sd card like this:
pi@~ $ df -h Filesystem Size Used Avail Use% Mounted on /dev/root 28G 6.6G 20G 26% / devtmpfs 430M 0 430M 0% /dev tmpfs 462M 25M 437M 6% /dev/shm tmpfs 462M 6.4M 456M 2% /run tmpfs 5.0M 4.0K 5.0M 1% /run/lock tmpfs 462M 0 462M 0% /sys/fs/cgroup /dev/mmcblk0p1 2.0G 60M 2.0G 3% /boot tmpfs 93M 4.0K 93M 1% /run/user/1000
I have tried to stop rsyslog and clean up the logs with no success:
pi@:~ $ sudo systemctl stop rsyslog Warning: Stopping rsyslog.service, but it can still be activated by: syslog.socket pi@:~ $ sudo systemctl disable rsyslog Synchronizing state of rsyslog.service with SysV service script with /lib/systemd/systemd-sysv-install. Executing: /lib/systemd/systemd-sysv-install disable rsyslog Removed /etc/systemd/system/syslog.service. Removed /etc/systemd/system/multi-user.target.wants/rsyslog.service. pi@:~ $ sudo rm /var/log/*.log pi@:~ $ df -h Filesystem Size Used Avail Use% Mounted on /dev/root 15G 14G 0 100% / devtmpfs 430M 0 430M 0% /dev tmpfs 462M 16M 446M 4% /dev/shm tmpfs 462M 13M 450M 3% /run tmpfs 5.0M 4.0K 5.0M 1% /run/lock tmpfs 462M 0 462M 0% /sys/fs/cgroup /dev/mmcblk0p1 247M 60M 187M 25% /boot tmpfs 93M 8.0K 93M 1% /run/user/1000
I believe that is related to web control cache as I upload files through web control and then delete them after use and it still keeps SD card full.
Looking forward to any new suggestions,
Thank you very much for fast replies guys:)
@ping You can check the size of directories using the
du
command. What totals do you get fordu -hc /var/log du -hc /opt/dsf/sd
@chrishamm
du -hc /var/log
7.6M totaldu -hc /opt/dsf/sd
34M total -
@ping Ok, so neither the logs nor the printer files take up that much space. You can run the
du -hc
command again on e.g./home
,/var
,/opt
,/usr
, and check if any of those are excessively large. -
/home approx 200Mb
/var 11Gb
/opt approx 200Mb
/usr 2.8 Gbpi@:~ $ du -hc /var 4.0K /var/lib/hp 4.0K /var/lib/apt/periodic du: cannot read directory '/var/lib/apt/lists/partial': Permission denied 4.0K /var/lib/apt/lists/partial 4.0K /var/lib/apt/lists/auxfiles 69M /var/lib/apt/lists 4.0K /var/lib/apt/mirrors/partial 8.0K /var/lib/apt/mirrors 69M /var/lib/apt 4.0K /var/lib/dhcp 604K /var/lib/usbutils 4.0K /var/lib/dbus 4.0K /var/lib/snmp 8.0K /var/lib/blueman 4.0K /var/lib/colord/icc du: cannot read directory '/var/lib/colord/.cache': Permission denied 4.0K /var/lib/colord/.cache 56K /var/lib/colord 8.0K /var/lib/ispell 4.0K /var/lib/dpkg/parts 320K /var/lib/dpkg/alternatives 48K /var/lib/dpkg/triggers 4.0K /var/lib/dpkg/updates 47M /var/lib/dpkg/info 50M /var/lib/dpkg 4.0K /var/lib/sudo/lectured 8.0K /var/lib/sudo du: cannot read directory '/var/lib/lightdm': Permission denied 4.0K /var/lib/lightdm 28K /var/lib/pam 4.0K /var/lib/openbox 4.0K /var/lib/git 24K /var/lib/ucf/cache 60K /var/lib/ucf du: cannot read directory '/var/lib/bluetooth': Permission denied 4.0K /var/lib/bluetooth 4.0K /var/lib/python 4.0K /var/lib/ntp 4.0K /var/lib/nfs/sm.bak 4.0K /var/lib/nfs/sm 12K /var/lib/nfs du: cannot read directory '/var/lib/polkit-1': Permission denied 4.0K /var/lib/polkit-1 8.0K /var/lib/alsa 12K /var/lib/dictionaries-common/wordlist 8.0K /var/lib/dictionaries-common/aspell 24K /var/lib/dictionaries-common 4.0K /var/lib/initramfs-tools 16K /var/lib/dhcpcd5 36K /var/lib/PackageKit 8.0K /var/lib/plymouth du: cannot read directory '/var/lib/private': Permission denied 4.0K /var/lib/private 12K /var/lib/sgml-base 4.0K /var/lib/vim/addons 8.0K /var/lib/vim 8.0K /var/lib/xkb 4.0K /var/lib/emacsen-common/state/package/installed 8.0K /var/lib/emacsen-common/state/package 4.0K /var/lib/emacsen-common/state/flavor/installed 8.0K /var/lib/emacsen-common/state/flavor 20K /var/lib/emacsen-common/state 24K /var/lib/emacsen-common du: cannot read directory '/var/lib/udisks2': Permission denied 4.0K /var/lib/udisks2 4.0K /var/lib/man-db 4.0K /var/lib/systemd/timesync 136K /var/lib/systemd/catalog 4.0K /var/lib/systemd/deb-systemd-helper-enabled/halt.target.wants 4.0K /var/lib/systemd/deb-systemd-helper-enabled/timers.target.wants 4.0K /var/lib/systemd/deb-systemd-helper-enabled/poweroff.target.wants 4.0K /var/lib/systemd/deb-systemd-helper-enabled/graphical.target.wants 4.0K /var/lib/systemd/deb-systemd-helper-enabled/network-online.target.wants 4.0K /var/lib/systemd/deb-systemd-helper-enabled/bluetooth.target.wants 4.0K /var/lib/systemd/deb-systemd-helper-enabled/remote-fs.target.wants 4.0K /var/lib/systemd/deb-systemd-helper-enabled/sockets.target.wants 4.0K /var/lib/systemd/deb-systemd-helper-enabled/multi-user.target.wants 4.0K /var/lib/systemd/deb-systemd-helper-enabled/reboot.target.wants 4.0K /var/lib/systemd/deb-systemd-helper-enabled/sysinit.target.wants 4.0K /var/lib/systemd/deb-systemd-helper-enabled/printer.target.wants 236K /var/lib/systemd/deb-systemd-helper-enabled 4.0K /var/lib/systemd/coredump 16K /var/lib/systemd/rfkill 4.0K /var/lib/systemd/timers 408K /var/lib/systemd 4.0K /var/lib/usb_modeswitch 4.1M /var/lib/aspell 16K /var/lib/xml-core 12K /var/lib/ghostscript/fonts 20K /var/lib/ghostscript/CMap 36K /var/lib/ghostscript 8.0K /var/lib/logrotate 4.0K /var/lib/raspberrypi/bootloader/backup 8.0K /var/lib/raspberrypi/bootloader 12K /var/lib/raspberrypi 4.0K /var/lib/misc 11G /var/lib/motion 11G /var/lib 3.7M /var/backups du: cannot read directory '/var/cache/apt/archives/partial': Permission denied 4.0K /var/cache/apt/archives/partial 36K /var/cache/apt/archives 40K /var/cache/apt du: cannot read directory '/var/cache/apparmor/ea9ed67a.0': Permission denied 4.0K /var/cache/apparmor/ea9ed67a.0 8.0K /var/cache/apparmor du: cannot read directory '/var/cache/cups': Permission denied 4.0K /var/cache/cups 8.0K /var/cache/unbound du: cannot read directory '/var/cache/lightdm': Permission denied 4.0K /var/cache/lightdm 4.4M /var/cache/debconf 32K /var/cache/man/ru 52K /var/cache/man/de 24K /var/cache/man/sr 24K /var/cache/man/sl 24K /var/cache/man/da 24K /var/cache/man/fr.ISO8859-1 24K /var/cache/man/id 28K /var/cache/man/sv 24K /var/cache/man/cs 32K /var/cache/man/nl 28K /var/cache/man/es 24K /var/cache/man/fi 24K /var/cache/man/pt_BR 52K /var/cache/man/fr 28K /var/cache/man/pl 24K /var/cache/man/zh_TW 24K /var/cache/man/tr 24K /var/cache/man/zh_CN 28K /var/cache/man/ja 24K /var/cache/man/fr.UTF-8 24K /var/cache/man/hu 28K /var/cache/man/it 24K /var/cache/man/ko 28K /var/cache/man/pt 1.6M /var/cache/man 40K /var/cache/dictionaries-common 4.0K /var/cache/PackageKit/downloads 8.0K /var/cache/PackageKit du: cannot read directory '/var/cache/private': Permission denied 4.0K /var/cache/private du: cannot read directory '/var/cache/ldconfig': Permission denied 4.0K /var/cache/ldconfig 240K /var/cache/fontconfig 6.2M /var/cache 4.0K /var/local du: cannot read directory '/var/spool/rsyslog': Permission denied 4.0K /var/spool/rsyslog du: cannot read directory '/var/spool/cups': Permission denied 4.0K /var/spool/cups du: cannot read directory '/var/spool/cron/crontabs': Permission denied 4.0K /var/spool/cron/crontabs 8.0K /var/spool/cron 20K /var/spool 4.0K /var/opt 4.0K /var/mail du: cannot read directory '/var/tmp/systemd-private-7d85e4b769d14331b6be8feb25ac6aa7-systemd-timesyncd.service-iBMXya': Permission denied 4.0K /var/tmp/systemd-private-7d85e4b769d14331b6be8feb25ac6aa7-systemd-timesyncd.service-iBMXya du: cannot read directory '/var/tmp/systemd-private-7d85e4b769d14331b6be8feb25ac6aa7-colord.service-8XTOUG': Permission denied 4.0K /var/tmp/systemd-private-7d85e4b769d14331b6be8feb25ac6aa7-colord.service-8XTOUG du: cannot read directory '/var/tmp/systemd-private-7d85e4b769d14331b6be8feb25ac6aa7-rtkit-daemon.service-U55l0X': Permission denied 4.0K /var/tmp/systemd-private-7d85e4b769d14331b6be8feb25ac6aa7-rtkit-daemon.service-U55l0X 16K /var/tmp 4.0K /var/log/hp/tmp 8.0K /var/log/hp 116K /var/log/apt 72K /var/log/cups du: cannot read directory '/var/log/lightdm': Permission denied 4.0K /var/log/lightdm du: cannot read directory '/var/log/private': Permission denied 4.0K /var/log/private 4.0K /var/log/proftpd 1.6M /var/log/motion 7.6M /var/log 11G /var 11G total
It seems like 11G is used by hidden files or do I understand something wrong?
@ping Not really - it seems you have a webcam set up on your system and it keeps writing to /var/lib/motion:
11G /var/lib/motion
That's far too much. I suggest you uninstall it and clean up the motion directory once, then start over and reconfigure motion so that it doesn't write photos automatically:
sudo apt purge motion sudo rm -rf /var/lib/motion
@chrishamm
I remember configuring motion to not store photos but it still stores something. I will investigate it more.SD card is now back to normal:
df -h Filesystem Size Used Avail Use% Mounted on /dev/root 15G 3.5G 11G 26% / devtmpfs 430M 0 430M 0% /dev tmpfs 462M 18M 444M 4% /dev/shm tmpfs 462M 13M 450M 3% /run tmpfs 5.0M 4.0K 5.0M 1% /run/lock tmpfs 462M 0 462M 0% /sys/fs/cgroup /dev/mmcblk0p1 247M 60M 187M 25% /boot tmpfs 93M 8.0K 93M 1% /run/user/1000
Thank you very much for solved issue!
dc42
dc42
