    Unexpected U Axis Homing Before Prints
    Using Duet Controllers
    148
    • JRCL
      JRCL last edited by
      I'm working on a custom machine that has a few additional axes outside your standard cartesian printer. However, I can't figure out why my U-axis goes to the end of its axis before every actual print. I played around with the print file, the homing file for that axis (homeu.g), homeall.g, and my config.g to no avail. Hoping for an extra set of eyes on things as to what might be causing it.
      ;start of actual print file
      M107
      M104 S210 ; set temperature
      G28		; home all
      G1 Z5 F5000 ; lift nozzle
      ; Filament gcode
      M109 S210 ; set temperature and wait for it to be reached
      G21 ; set units to millimeters
      G90 ; use absolute coordinates
      M82 ; use absolute distances for extrusion
      G92 E0
      G1 Z0.200 F9000.000
      ; HOME U
      M400
      M913 U50  ; drop motor current to 70%
      M400 G91; relative positioning
      G1 H1 U700 F40000 ; move quickly to U axis endstop and stop there (first pass)
      G1 H2 U-29 F40000 ; move quickly to backwards
      G90 ; absolute positioning
      M400
      M913 U100 Y100 ; return current to 100%
      M400
      ; config.g file
      M574 X1 S3                                      ; configure sensorless endstop for low end on X
      M574 Y1 S3                                      ; configure sensorless endstop for low end on Y
      M574 U1 S1 P"e0stop"                  ; configure switch-type (e.g. microswitch) endstop for low end on U via pin estop
      M574 V1 S3 					; configure sensorless endstop for low end on V
      M915 X Y R0 F0 S5  			; configure stall detection for X and Y
      M915 V R0 F0 S40			; configure stall detection for V
      M915 V R0 F0 S5				; configure stall detection for Z
      fcwilt Phaedrux 2 Replies Last reply Reply Quote 0
      • fcwilt
        fcwilt @JRCL last edited by
        @jrcl
        Sorry but I don't understand.
        At the start of a print you are homing all. That would include the U axis.
        JRCL 1 Reply Last reply Reply Quote 0
        • JRCL
          JRCL @fcwilt last edited by
          @fcwilt yeah it's kind of weird to explain, but maybe part of my confusion too. My G28 command does correctly home all the axes. However, right when the nozzle reaches the set temperature and the print starts the U axis moves again and goes to its end stop (which is not at home) and stays there the remainder of the print until I inevitably abort. Hopefully that helps describe the issue a little better
          • deckingman
            deckingman @JRCL last edited by
            @jrcl What happens if you run homeall stand alone rather than as part of a print? Does the U axis stay in the correct position? If so, then the fault is elsewhere. Can you post your entire homeall.g and your entire configuration file(s) including config-override.g if you use it.
            • JRCL
              JRCL @deckingman last edited by
              @deckingman If I run home all or home U it doesn't do it, so I agree I figured it was likely configuration based too. However, I haven't looked at the config-override yet! I'm new to this all and frankly, I'm not familiar with that file so much but it looks like maybe that is my issue. Here it is though with my home all:
              ; Home All
              M98 P"homev.g"
              M98 P"homeu.g"
              M98 P"homex.g"
              M98 P"homey.g"
              M98 P"homez.g"
              ; Configuration file for Duet WiFi (firmware version 3.3)
              ; generated by RepRapFirmware Configuration Tool v3.3.10 on Sun Jan 09 2022 20:46:24 GMT+0100 (Централноевропейско стандартно време)
              M575 P1 S1 B57600                               ; enable support for PanelDue
              G90                                             ; send absolute coordinates...
              M83                                             ; ...but relative extruder moves
              M550 P"RL1 Proto"                              ; set printer name
              M551 P"SkiBum98"								; set password
              M552 S1                                         ; enable Wifi
              M586 P0 S1                                      ; enable HTTP
              M586 P1 S0                                      ; disable FTP
              M586 P2 S0                                      ; disable Telnet
              M569 P0 S1                                      ; physical drive 0 goes forwards (eventually X)
              M569 P1 S1                                      ; physical drive 1 goes forwards (eventually Y)
              M569 P2 S1                                      ; physical drive 2 goes forwards (eventually Z)
              M569 P3 S1                                      ; physical drive 3 goes forwards (eventually E)
              M569 P4 S0										; physical drive 4 goes backwards (eventually U)
              M569 P5 S1										; physical drive 5 goes forwards (eventually V1)
              M569 P6 S0										; physical drive 6 goes backwards (eventually V2)
              ; Motor Speeds and Accelerations
              M584 X0 Y1 Z2 E3 U4 V5:6                               ; set drive mapping
              M350 X16 Y16 Z16 E64 U16 V16 I0                      ; configure microstepping without interpolation
              M92 X80.00 Y80.00 Z400.00 E80.00 U400.00 V80.00        ; set steps per mm
              M566 X900.00 Y900.00 Z60.00 E120.00 U60.00 V900.00     ; set maximum instantaneous speed changes (mm/min)
              M203 X6000.00 Y6000.00 Z180.00 E1200.00 U180.00 V6000.00 ; set maximum speeds (mm/min)
              M201 X500.00 Y500.00 Z20.00 U20.00 E250.00 U20.00 V500.00     ; set accelerations (mm/s^2)
              M906 X800 Y800 Z800 E800 U800 V 800 I100                ; set motor currents (mA) and motor idle factor in per cent
              M208 X0 Y0 Z0 U0 V0 S1                                ; set axis minima
              M208 X135 Y135 Z200 U700 V400 S0                          ; set axis maxima
              M950 S0 C"duex.pwm1" 							; Duet 2 WiFi/Ethernet + DueX2/5
              M558 P9 C"^zprobe.in" H5 F120 T6000 			; Duet 2 WiFi/Ethernet, DueX2/5
              G31 P500 X25 Y0 Z2.5            				; set Z probe trigger value, offset and trigger height
              M557 X15:215 Y15:195 S20        				; define mesh grid
              M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8   ; configure sensor 1 as thermistor on pin e0temp
              M950 H1 C"e0heat" T1                            ; create nozzle heater output on e0heat and map it to sensor 1
              M307 H1 B0 S1.00 D5                              ; disable bang-bang mode for heater  and set PWM limit
              M308 S2 P"e1temp" Y"thermistor" T100000 B4725 C7.06e-8   ; configure sensor 1 as thermistor on pin e0temp
              M950 H2 C"e1heat" T2                            ; create nozzle heater output on e0heat and map it to sensor 1
              M307 H2 B0 S1.00
              M950 F0 C"fan0" Q500 							; create fan 0 on pin fan0 and set its frequency
              M106 P0 S0 H-1       							; set fan 0 value. Thermostatic control is turned off
              M950 F1 C"fan1" Q500 							; create fan 1 on pin fan1 and set its frequency
              M106 P1 S1 H1 T45    							; set fan 1 value. Thermostatic control is turned on
              M563 P0 D0 H1 F0                  				; tool 0 uses extruder drive 0, heater 1 and fan 0 (part cooling fan)
              G10 P0 X0 Y0 Z0                                 ; set tool 0 axis offsets
              G10 P0 R0 S0 									; set initial tool 0 active and standby temperatures to 0C
              M563 P1 H2
              G10 P1 X0 Y0 Z0
              G10 P1 R0 S0
              ; Epilogue
              M556 S100 X0 Y0 Z0                                 ; Put your axis compensation here
              M912 P0 S0                                         ; Put your CPU temperature sensor correction here
              M501                                               ; load saved parameters from non-volatile memory
              T0                                                 ; select first tool
              ; config-override.g file generated in response to M500 at 2022-04-10 14:40
              ; Heater model parameters
              M307 H1 R3.382 C178.444:87.318 D4.85 S1.00 V24.2 B0 I0
              M307 H2 R2.429 C140.000:140.000 D5.50 S1.00 V0.0 B0 I0
              ; Workplace coordinates
              G10 L2 P1 X0.00 Y0.00 Z0.00 U0.00 V0.00
              G10 L2 P2 X0.00 Y0.00 Z0.00 U0.00 V0.00
              G10 L2 P3 X0.00 Y0.00 Z0.00 U0.00 V0.00
              G10 L2 P4 X0.00 Y0.00 Z0.00 U0.00 V0.00
              G10 L2 P5 X0.00 Y0.00 Z0.00 U0.00 V0.00
              G10 L2 P6 X0.00 Y0.00 Z0.00 U0.00 V0.00
              G10 L2 P7 X0.00 Y0.00 Z0.00 U0.00 V0.00
              G10 L2 P8 X0.00 Y0.00 Z0.00 U0.00 V0.00
              G10 L2 P9 X0.00 Y0.00 Z0.00 U0.00 V0.00
                Phaedrux Moderator @JRCL last edited by
                @jrcl said in Unexpected U Axis Homing Before Prints:
                Remove the H2. It may be hiding an error message if the homing has actually failed.
                Can you post a sliced gcode file so we can see what happens at the start of a print?
                Are you using start.g?
                Can you send M122 and M98 P"config.g" and post the results?
                V 800
                You have a space between the V and 800 in your M906 command.
                  dc42 administrators @JRCL last edited by
                  @jrcl your config.g file indicates that you have a U axis minimum endstop, but your G1 H1 U move in homeu.g homes towards axis maximum. So one of those is wrong.
                  JRCL 1 Reply Last reply Reply Quote 2
                  • JRCL
                    JRCL @Phaedrux last edited by
                    This post is deleted!
                    • JRCL
                      JRCL @dc42 last edited by
                      @dc42 This did it!!!! 🙌 thank you so much, an H2 instead of an H1 solved the issue
                      • fcwilt
                        fcwilt @JRCL last edited by fcwilt
                        What about the problem mentioned regarding the specified position of the endstop and the homing code moving the wrong way?
                        And where did you change H1 to H2? That should not have solved the problem.
                        Thanks.
                          Nope. That may hide the issue.
