    Duet Wifi Thermocoupler Daughter board issue.
    • zerogee
      zerogee last edited by
      So I setup my board with the Duet Thermocoupler daughter board, but i am not getting any readings for "current" except a 2000c and I/O error fault. I read just about every wiki on this site and tried numerous things but nothing changes. i'm using E3D TYPE K THERMOCOUPLE (CARTRIDGE) and have set it in the 0 slot (using 100) on the daughterboard, but nothing i'm still getting the i/o error and 2000c. I did try connecting the Thermocoupler to E0 thermoistore1 on the board and change the G Code to see if maybe the Thermocoupler wire was bad. I did start getting a reading , but it was high like 350c and stable. but it was reading something. so, what does tell me? I'm thinking of either two things; my G code is wrong or the daughter board is bad. As i have tried just about every variation of G code I could think of. I'm at a lost. and i don't know how to troubleshoot the daughter board. I did try taking a wire and jumping over the connection on the daughterboard (read somewhere in the forum or wiki) and still got the same readings. I am open to any suggestions at this point.
      NOTE: this is a new printer build, so it hasn't even printed anything yet.
      This is my config.g file as it is now:
      ; Configuration file for Duet WiFi (firmware version 1.17)
      ; generated by RepRapFirmware Configuration Tool on Fri Oct 06 2017 22:21:06 GMT-0500 (Central Daylight Time)
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      M667 S1 ; Select CoreXY mode
      M208 X300 Y300 Z300 S0 ; Set axis maxima
      M574 X1 Y1 Z2 S0 ; Define active low and unused microswitches
      M558 P1 X0 Y0 Z0 H5 F120 T6000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
      G31 P600 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
      M557 X15:285 Y15:285 S20 ; Define mesh grid
      M92 X80 Y80 Z4000 E420 ; Set steps per mm
      M203 X6000 Y6000 Z180 E1200 ; Set maximum speeds (mm/min)
      M201 X500 Y20 Z250 E250 ; Set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      ;M143 S400 ; Set maximum heater temperature to 260C
      ;M305 P1 T100000 B4138 C0 R4700 X100 ; Set thermistor + ADC parameters for heater 1 and remap it to channel 100
      M305 P1 X100
      M563 P0 D0 H1 ; Define tool 0
      M550 PCoreXY ; Set machine name
      M552 S1 ; Enable network
      M587 Sxxxxxxx P"xxxxxxxxxxxxx" ; Configure access point. You can delete this line once connected
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      thanks in advance
      -curtis
        Which version of the thermocouple board is it? If it's the newer version with two Error LEDs on it, you need X150 in the M305 command instead of X100 - see the instructions on the wiki.
        • zerogee
          That was it. I must have read the wiki a hundred times and did not catch the version of the daughter board. set my G code to 150 and voila, it works. thanks.
            I just checked the wiki and although the instruction to use channels 150-153 was included in the Hardware paragraph, it wasn't mentioned in the Firmware Configuration paragraph. I'm sorry if this misled you. I have now corrected it.
