    Can't change heater setpoint individually
    PanelDue
    • Mike685
      Mike685 last edited by
      There is a problem with paneldue 7i. I have a single tool that uses 3 heaters. The problem is changing one setpoint on the paneldue changes them all to that value. The only way to set my heaters individually is to send a G10 P1 Sxx:xx:xx, where x is the setpoint. It would be more useful if the paneldue let the user set the heaters individually even if they are on the same tool instead of sending a gcode.
      Here is my config: config (1).g
        Can you tell us what firmware version you are running on the Duet and PanelDue?
        M140 H-1                                    ; disable heated bed (overrides default heater mapping)
        M308 S0 P"spi.cs1" Y"rtd-max31865"          ; configure sensor 0 as PT100 on pin spi.cs1
        M308 S1 P"spi.cs2" Y"rtd-max31865"			; configure sensor 1 as PT100 on pin spi.cs2
        M308 S2 P"spi.cs3" Y"rtd-max31865" 			; configure sensor 2 as PT100 on pin spi.cs3
        M950 H3 C"bedheat" T0                   ; create top heater output on exp.heater3 and map it to sensor 0
        M950 H1 C"e0heat" T1                        ; create bottom heater output on e0heat and map it to sensor 1
        M950 H2 C"e1heat" T2                        ; create nozzle heater output on e1heat and map it to sensor 2
        M307 H0 A941.2 C813.2 D21.6 S1.0 B0         ; Set Heater parameter Barrel Top
        M307 H1 A941.2 C813.2 D21.6 S1.0 B0         ; Set Heater parameter Barrel Bottom
        M307 H2 A795.3 C921 D10.4 S1.0 B0			; Set Heater parameter Barrel Nozzle
        M143 H0 S500                                ; set temperature limit for heater 0 to 500C
        M143 H1 S500                                ; set temperature limit for heater 1 to 500C
        M143 H2 S500                                ; set temperature limit for heater 2 to 500C
        M563 P0 D0 H1:2:3 F0              	    ; define tool 0
        G10 P0 X0 Y0 Z0                             ; set tool 0 axis offsets
        G10 P0 R0 S0                                ; set initial tool 0 active and standby temperatures to 0C
        Your heater config is a little confusing, but I assume it otherwise works when using G10 commands?
        • M7460
          M7460 last edited by
          I also have this issue - is there a fix ?
          Martin
            Phaedrux Moderator @M7460 last edited by Phaedrux
            @m7460 Can you provide some information?
            Share your config.g?
