    Duet RepRapFirmware Integration plugin FOR CURA
    • paolozampini1973
      paolozampini1973 last edited by
      Good evening can someone tell me why the print plugin only works for me Ultimaker Cura 4.13.1 AND DOESN'T WORK Ultimaker Cura Enterprise 4.10.0?
      resam 1 Reply Last reply Reply Quote 0
      • resam
        resam @paolozampini1973 last edited by
        @paolozampini1973 hi! I wasn't aware that there is a Cura Enterprise version. Does it use the same marketplace to install plugins, or did you install the Cura-DuetRRF plugin straight from the GitHub releases? https://github.com/Kriechi/Cura-DuetRRFPlugin
        The most recent plugin version v1.2.5 bumped the supported Cura version to 4.11 and higher. So, you could try to install the plugin v1.2.4 or older, which should be compatible with Cura 4.10 although I never tested this with the Cura Enterprise variant.
        Take a look at the manual installation instructions here: https://github.com/Kriechi/Cura-DuetRRFPlugin#manual-installation
        paolozampini1973 1 Reply Last reply Reply Quote 0
        • paolozampini1973
          paolozampini1973 @resam last edited by
          @resam said in Duet RepRapFirmware Integration plugin FOR CURA:
          Thanks for the suggestion I hadn't thought of an older older version However now it works what I wanted to tell you also that Ultimaker Cura Enterprise 4.10.0 is very much much better than other versions Ultimaker Cura takes less time with 50% better quality I am using it 2 days ago and I have already made three large molds try it and you will see that it works in a different way Otherwise it takes less time consumes less material and the quality is much higher Then let me know.
          this version finishes working a complete internal wall and then makes the complete external wall and then goes to make the other prints practically does not jump from one point to another you have much less relationships and much less movement
