    Solved heater-fault.g and filament-error.g
    Documentation
    • oliof
      oliof last edited by
      Reading documentation on triggers, I noticed heater-fault.g and filament-error.g are not listed in the System Macros section in the documentation. I think they should be added, since at least heater-fault.g is kind-of critical.
      <>Creality CR-20 IDEX Duet3 mini 5+<>RatRig V-Minion SKR RRF 1.1<>
      droftarts 1 Reply Last reply Reply Quote 3
      • droftarts
        droftarts administrators @oliof last edited by
        @oliof Thanks, I've added a section on these (and the driver error/warnings) to the Macros page that links to the Events page: https://docs.duet3d.com/en/User_manual/Tuning/Macros#errors-and-events
        • Topic has been marked as a question  droftarts droftarts
        • Topic has been marked as solved  droftarts droftarts
