    Cura thumbnails are not shown
    Duet Web Control
    1318
    • tapirath
      tapirath last edited by
      Hi all,
      Here is a snippet from the latest Cura. Looks like the format seems fine and indeed the image format used is PNG, so I'm not sure why DWC can't view them.
      Any ideas?
        dc42 administrators @tapirath last edited by
        @tapirath are you running RRF and DWC 3.4? Also DSF 3.4 if using SBC.
        tapirath 1 Reply Last reply Reply Quote 0
        • jay_s_uk
          jay_s_uk last edited by jay_s_uk
          Cura 4.13.1 works fine with @resam plugin.
          The duet plugin currently doesn't work with cura 5 beta so the thumbnails may not work correctly until the plugin works again
          • tapirath
            tapirath @dc42 last edited by
            I'm running 3.4 stable both RRF and DWC. Standalone mode.
            The thumbnail is created with the official post-processing plugin of cura.
            @jay_s_uk I'm not sure it has anything to do with Cura version. It's the exact same post-processing script.
            • tapirath
              Here is the link to the script: https://github.com/Ultimaker/Cura/blob/master/plugins/PostProcessingPlugin/scripts/CreateThumbnail.py
              You can switch between master and 5.0 branch. It looks same to me.
              resam 1 Reply Last reply Reply Quote 0
              • resam
                resam @tapirath last edited by resam
                Cura-DuetRRF Plugin for Cura V5 is already submitted for review by the Ultimaker Marketplace team - usually takes a few days before the approve and its available. Until then, you can use the manual installation method from the next branch of the plugin - and download the zip file also from the next branch: https://github.com/Kriechi/Cura-DuetRRFPlugin/tree/next#manual-installation
                tapirath 1 Reply Last reply Reply Quote 2
                • tapirath
                  tapirath @resam last edited by tapirath
                  @resam
                  Maybe I'm missing an information here but my problem has no relevance to the Cura RRF plugin. I don't use that plugin. This is a post-processing script that embeds the thumbnail in the gcode and I upload the gcode manually via DWC.
                  • resam
                    @tapirath I didn't specifically comment about your case - just general information.
                    But regarding your case: the post-processing script is not generating valid thumbnail comments:
                    https://github.com/Ultimaker/Cura/blob/5330e53ae60030d6ac4061642e818fb40ffafcb1/plugins/PostProcessingPlugin/scripts/CreateThumbnail.py#L40
                    the width and height need to be separated by an x, not a space character. At least that's what the plugin is doing - and its working there.
                    tapirath dc42 2 Replies Last reply Reply Quote 1
                    • tapirath
                      @dc42 would you be willing to fix it on your end or should report to Cura?
                      • resam
                        @tapirath thats a Cura problem - so please report it to them. I'm not even sure if they built this specifically to be compatible with Duet / RepRapFirmware.
                        • tapirath
                          @resam said in Cura thumbnails are not shown:
                          done: https://github.com/Ultimaker/Cura/pull/11917
                          tapir created this issue in Ultimaker/Cura
                          open Fix thumbnail format #11917
                            dc42 administrators @resam last edited by
                            Yes, RRF expects a 'x' between the width and height (which is what PrusaSlicer generates), not a space. Best get it fixed in Cura because it may not only affect RRF.
