    Conditional code for layer height
    Gcode meta commands
    • tapirath
      tapirath last edited by
      I'm trying to convert this PrusaSlicer code to a RRF macro. Is there a way to achieve it? where can I find the documentation for all the possible variables I can use?
      ; 0.2mm layer, 8 bands 5mm each, total height 40mm
      {if layer_num== 1}M572 D0 S0.0
      {elsif layer_num== 25}M572 D0 S0.05
      {elsif layer_num== 50}M572 D0 S0.10
      {elsif layer_num== 75}M572 D0 S0.15
      {elsif layer_num== 100}M572 D0 S0.20
      {elsif layer_num== 125}M572 D0 S0.25
      {elsif layer_num== 150}M572 D0 S0.30
      {elsif layer_num== 175}M572 D0 S0.35
      {endif}
        dc42 administrators @tapirath last edited by
        @tapirath something like this (not tested!):
        if exists(job.layer)
          if job.layer = 1
            M572 D0 S0.0
          elif job.layer = 25
            M572 D0 S0.05
        and so on. Object model job.layer will only be present and correct if the GCode includes recognised layer number comments.
          Maybe take a look here: https://forum.duet3d.com/topic/26272/incremental-pressure-advance-m572-tuning-macros
          • tapirath
            Perfect thank you both
            • mikeabuilder
              mikeabuilder last edited by
              If you do write this macro in RRF, you'll still need to insert a custom bit of gcode in your slicer that is called on every layer change. And that custom gcode is an M98 P"<your macro name>". This will call the macro every time a layer is changed. After doing precisely this myself, I found that I preferred to do that work with slicer code.
              tapirath 1 Reply Last reply Reply Quote 1
              • tapirath
                tapirath @mikeabuilder last edited by
                @mikeabuilder
                I prefer the macro because
                1- Cura doesn't have conditional gcode
                2- I can use the macro with any Slicer without changing it
                • ELAD
                  ELAD last edited by
                  This post is deleted!
