    Extend the Duet 2 WiFi's WiFi Module cable
    • TRATOONundefined
      TRATOON
      Does anybody know what wire the Wifi Module on my Duet 2 Wifi (with external antenna) uses, as I need to get a longer version of it? And could you link it as well?
      dc42undefined Stephen6309undefined 2 Replies Last reply Reply Quote 0
        dc42 administrators @TRATOON
        @tratoon I believe (but I am not certain) that what we supply is a UFL to SMA cable, and a SMA antenna. If that's the case then a standard SMA M-F cable may work. Alternatively, look for a longer UFL to SMA cable, such as https://cpc.farnell.com/multicomp/r-134g7210300cb/cable-u-fl-sma-ip67-rp-300mm/dp/CN22189 or https://www.amazon.co.uk/BOOBRIE-Connector-Pigtail-Extension-Wireless/dp/B07R7V6YLL.
        • Stephen6309undefined
          Stephen6309 @TRATOON
          @tratoon I use this to extend: www.amazon.com/gp/product/B07W6YRXVL
          • TRATOONundefined TRATOON has marked this topic as solved
