    Help with Duet 3 6HC, Pi 4 and SSH
    • rmilyardundefined
      rmilyard
      I used the DuetPI image: 2022-03-18-DuetPi
      I put the SSH file and wpa_supplicant.conf files in boot of the SD card. I found the pi's ip and the duet gui works. When I try to use putty (ssh) I get Network error: Software caused connection abort.
      When I check SD card looks like SSH file is gone. However I still can't SSH into pi. Ideas?
      • chrishammundefined
        chrishamm administrators @rmilyard
        @rmilyard I haven't tried the SSH file in a while in favour of the advanced settings of the Raspberry Pi Imager but I'd expect it should still work. If you are on the stock DuetPi image, you can enable SSH using an M-code as well. You can send this using the console:
        M586 P2 T1 S1
        Duet software engineer
