    M106 handling of X (max fan speed) parameter
    Documentation
    • gloomyandyundefined
      gloomyandy
      Hi, I think there is a small error/confusion in the M106 documentation. The latest doc for M106 describes how the X parameter (max fan speed is handled as):
      The L parameter defines the minimum PWM value that is usable with this fan. If a lower value is commanded that is not zero, it will be rounded up to this value.
      The X parameter defines the same for a maximum PWM value. If a higher value is commanded, it will be rounded down to this value.
      But looking at the code:
      https://github.com/Duet3D/RepRapFirmware/blob/3.4-dev/src/Fans/LocalFan.cpp#L76
      		reqVal = (val <= 0.0) ? 0.0 : max<float>(val * maxVal, minVal);		// scale the requested PWM by the maximum, enforce the minimum
      It looks like the requested value (from the S parameter) is scaled to be between 0..<max value> and that value is then rounded up to the minimum. Which seems to make more sense than the rounding down described in the docs.
        droftarts administrators @gloomyandy
        @gloomyandy Thanks Andy, I'll check with @dc42 (though I'm sure you are correct!) and amend.
          M106 entry updated.
          • droftartsundefined droftarts marked this topic as a question
          • droftartsundefined droftarts has marked this topic as solved
