    Solved DWC Error: M32: Cannot set file to print...
    Duet Web Control
    • Form3DCP
      Form3DCP last edited by Form3DCP
      I have been using Duet boards for a couple years now and I have run across this issue on a Duet 3 MB6HC with SBC RPI4 and cannot find anyone else having this issue. Everytime I try to run a print from the DWC it gives this "Error: M32: Cannot set file to print, because a file is already being printed" then changes status from idle to printing and doesn't do anything but stay at 0% progress. I was able to configure and move the machine around and I have printed with this mainboard and sbc with no problems before. Reformatting SD card, reloading firmware, and using different slicers yielded the same result. I am running firmware 3.3 with DWC 3.4. I have no idea what is happening here, please help! Update: I can run prints from the macros directory but this isn't ideal.
      M122 Output:
      M122
      RepRapFirmware for Duet 3 MB6HC version 3.3 (2021-06-15 21:45:47) running on Duet 3 MB6HC v1.01 or later (SBC mode)
      Board ID: 08DJM-956L2-G43S8-6J1FA-3SJ6Q-1B0AG
      Used output buffers: 1 of 40 (12 max)
      Static ram: 150904
      Dynamic ram: 61068 of which 0 recycled
      Never used RAM 142220, free system stack 152 words
      Tasks: SBC(ready,18.7%,334) HEAT(delaying,0.0%,405) Move(notifyWait,0.0%,241) CanReceiv(notifyWait,0.0%,908) CanSender(notifyWait,0.0%,362) CanClock(delaying,0.0%,339) TMC(notifyWait,7.3%,59) MAIN(running,74.0%,1131) IDLE(ready,0.0%,29), total 100.0%
      Owned mutexes: HTTP(MAIN)
      Last reset 00:59:57 ago, cause: software
      Last software reset at 2022-04-29 14:27, reason: User, none spinning, available RAM 139356, slot 0
      Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
      Error status: 0x00
      Step timer max interval 163
      MCU temperature: min 40.2, current 40.7, max 40.7
      Supply voltage: min 24.0, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.2, current 12.2, max 12.3, under voltage events: 0
      Driver 0: position 0, standstill, reads 52090, writes 0 timeouts 0, SG min/max not available
      Driver 1: position 0, standstill, reads 52090, writes 0 timeouts 0, SG min/max not available
      Driver 2: position 2000, standstill, reads 52090, writes 0 timeouts 0, SG min/max not available
      Driver 3: position 0, standstill, reads 52090, writes 0 timeouts 0, SG min/max not available
      Driver 4: position 0, standstill, reads 52090, writes 0 timeouts 0, SG min/max not available
      Driver 5: position 0, standstill, reads 52089, writes 0 timeouts 0, SG min/max not available
      Date/time: 2022-04-29 16:03:12
      Slowest loop: 0.45ms; fastest: 0.03ms
      === Storage ===
      Free file entries: 10
      === MainDDARing ===
      Scheduled moves 14, completed moves 14, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
      === AuxDDARing ===
      Bed heaters = -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
      Segments left: 0
      Movement lock held by null
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === CAN ===
      Messages queued 1865, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 7, free buffers 49 (min 49), ts 1865/1865/0
      Tx timeouts 0,0,0,0,0,0
      === SBC interface ===
      State: 4, failed transfers: 1, checksum errors: 0
      Last transfer: 2ms ago
      RX/TX seq numbers: 44887/44887
      SPI underruns 0, overruns 0
      Disconnects: 1, timeouts: 1, IAP RAM available 0x2c810
      Buffer RX/TX: 0/0-0
      === Duet Control Server ===
      Duet Control Server v3.4.0
      Code buffer space: 4096
      Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
      Full transfers per second: 4088.44, max time between full transfers: 24.8ms, max pin wait times: 9.9ms/12.1ms
      Codes per second: 0.00
      Maximum length of RX/TX data transfers: 2988/64
      Here is my configuration.g:
      ; Configuration file for Duet 3 (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Thu Apr 28 2022 14:12:14 GMT-0500 (Central Daylight Time)
      M550 P"Duet 3"                                     ; set printer name
      M569 P40.0 S1 R0 T20:20:20:20
      M569 P0.0 S0                                       ; physical drive 0.0 goes forwards
      M569 P0.1 S0                                       ; physical drive 0.1 goes forwards
      M569 P0.2 S0
      M569 P0.3 S0
      M569 P0.4 S0
      M569 P0.5 S0
      M584 X40.0 Y0.0:1 Z0.2:3:4:5                                ; set drive mapping
      M350 X16 Y16 Z16 I1                                ; configure microstepping with interpolation
      M92 X8.00 Y400.00 Z400.00                         ; set steps per mm
      M566 X1000.00 Y800.00 Z60.00                        ; set maximum instantaneous speed changes (mm/min)
      M203 X1800.00 Y1500.00 Z500.00                     ; set maximum speeds (mm/min)
      M201 X1000.00 Y800.00 Z20.00                        ; set accelerations (mm/s^2)
      M906 Y4200 Z4200 I30                          ; set motor currents (mA) and motor idle factor in per cent
      M208 X700 Y1100 Z650 S0                            ; set axis maxima
      M574 X1 S1 P"!io0.out"
      M574 Y1 S1 P"!io1.out+!io6.out"
      M574 Z1 S1 P"!io2.out"
      M558 P0 H5 F120 T6000
      M557 X15:215 Y15:195 S20
      Here is the debug when I try to run a print:
      Apr 29 14:19:17 duet3 DuetControlServer[414]: [debug] Waiting for execution of M32 "0:/gcodes/please.gcode"
      Apr 29 14:19:17 duet3 DuetControlServer[414]: [debug] Processing M32 "0:/gcodes/please.gcode"
      Apr 29 14:19:17 duet3 DuetControlServer[414]: [info] Selected file /opt/dsf/sd/gcodes/please.gcode
      Apr 29 14:19:17 duet3 DuetControlServer[414]: [debug] Waiting for finish of M32 "0:/gcodes/please.gcode"
      Apr 29 14:19:17 duet3 DuetControlServer[414]: [debug] HTTP: Sent M32 "0:/gcodes/please.gcode", remaining space 1480, needed 56
      Apr 29 14:19:17 duet3 DuetControlServer[414]: [info] Starting macro file start.g on channel File
      Apr 29 14:19:17 duet3 DuetControlServer[414]: [debug] Completed M32 "0:/gcodes/please.gcode" => Error: M32: Cannot set file to print, because a file is already being printed
      Apr 29 14:19:17 duet3 DuetControlServer[414]: [debug] IPC#33: Connection closed
      Apr 29 14:19:22 duet3 DuetControlServer[414]: [debug] Completed G28
      Apr 29 14:19:22 duet3 DuetControlServer[414]: [debug] Finished codes from macro file start.g
      Apr 29 14:19:22 duet3 DuetControlServer[414]: [info] Finished macro file start.g
      Apr 29 14:19:22 duet3 DuetControlServer[414]: [debug] File: Disposing macro file start.g
      Apr 29 14:19:22 duet3 DuetControlServer[414]: [debug] Requesting update of key inputs, seq 14 -> 17
      Apr 29 14:19:22 duet3 DuetControlServer[414]: [debug] Updated key inputs
      Apr 29 14:19:22 duet3 DuetControlServer[414]: [debug] Requesting update of key move, seq 39 -> 41
      Apr 29 14:19:22 duet3 DuetControlServer[414]: [debug] Updated key move
      Apr 29 14:25:20 duet3 DuetControlServer[414]: [debug] IPC#34: Got new UNIX connection, checking permissions...
      Apr 29 14:25:20 duet3 DuetControlServer[414]: [debug] IPC#34: Granting full DSF permissions to external plugin
      Apr 29 14:25:20 duet3 DuetControlServer[414]: [debug] IPC#34: Command processor added
      Apr 29 14:25:20 duet3 DuetControlServer[414]: [debug] IPC#34: Received command ResolvePath
      Apr 29 14:25:20 duet3 DuetControlServer[414]: [debug] IPC#34: Connection closed
      • Form3DCP
        This post is deleted!
          Your Pi is running 3.4 but the Duet is only running 3.3.
          Have you tried running sudo apt update and sudo apt upgrade on the Pi yet? If so, it appears the firmware update on the Duet was not successfully applied. Try running the update again. If it still doesn't update when you send M115 to check then you'll need to manually initiate the update by sending M997 in the gcode console tab in DWC. If that still doesn't update the Duet3 firmware then you'd need to use the direct USB connection to a PC and use the Bossa software to flash it directly.
          Form3DCP 1 Reply Last reply Reply Quote 1
          • Form3DCP
            Form3DCP @Phaedrux last edited by
            @phaedrux
            That worked! Just had to send M997, can't believe it was that simple. Thank you so much! I would've been scratching my head for days.
            • Topic has been marked as a question  Phaedrux Phaedrux
            • Topic has been marked as solved  Phaedrux Phaedrux
