Duet2 ethernet DWC lost connection while printing
My Duet2 ethernet DWC lost connection while printing.
Refreshing the page in chrome results in: This site can’t be reached jubilee.lan refused to connect.
Can still ping and telnet.
Duet and telnet both giving a lot of: Warning: Driver 1 warning: over temperature warning
The driver warning stopped when print finished, but chrome still can't connect.
I also issued a M122 from telnet see below.
MCU temperature maxed at 47.0Anything I should try before rebooting it?
What does Error status: 0x14 mean?Thanks
M122 via telnet, after print complete:
=== Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0 (2022-03-15 18:58:31) running on Duet Ethernet 1.02 or later + DueX5v0.11 Board ID: 0JD0M-9P6B2-NJ4S4-6JKDA-3SJ6P-KB2QK Used output buffers: 1 of 24 (24 max) === RTOS === Static ram: 23868 Dynamic ram: 74348 of which 228 recycled Never used RAM 10108, free system stack 98 words Tasks: NETWORK(ready,82.8%,212) HEAT(notifyWait,0.2%,307) Move(notifyWait,13.5%,295) DUEX(notifyWait,0.0%,24) MAIN(running,3.4%,360) IDLE(ready,0.1%,30), total 100.0% Owned mutexes: === Platform === Last reset 02:02:19 ago, cause: power up Last software reset at 2022-03-26 18:44, reason: User, GCodes spinning, available RAM 11812, slot 2 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x14 Step timer max interval 0 MCU temperature: min 24.7, current 44.6, max 47.0 Supply voltage: min 24.0, current 24.1, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/2, heap memory allocated/used/recyclable 2048/196/176, gc cycles 16 Events: 82454 queued, 82454 completed Driver 0: standstill, SG min 0 Driver 1: standstill, SG min 0 Driver 2: standstill, SG min 0 Driver 3: standstill, SG min n/a Driver 4: standstill, SG min n/a Driver 5: standstill, SG min 0 Driver 6: standstill, SG min 0 Driver 7: standstill, SG min 0 Driver 8: standstill, SG min 0 Driver 9: standstill, SG min n/a Driver 10: Driver 11: Date/time: 2022-04-30 13:12:15 Cache data hit count 4294967295 Slowest loop: 353.22ms; fastest: 0.12ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 9 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 5.8ms, write time 221.2ms, max retries 0 === Move === DMs created 83, segments created 28, maxWait 255201ms, bed compensation in use: mesh, comp offset 0.000 === MainDDARing === Scheduled moves 506070, completed 506070, hiccups 0, stepErrors 0, LaErrors 0, Underruns [3, 0, 11], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 0 is on, I-accum = 0.0 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty === DueX === Read count 13, 0.11 reads/min === Network === Slowest loop: 318.38ms; fastest: 0.02ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(2), 1 sessions HTTP sessions: 0 of 8 Interface state active, link 100Mbps full duplex
Unplugging and replugging the ethernet cable brought it back.
