    Solved Failed to enable endstop error using BL Touch
    My Duet controlled machine
    • TRATOON
      TRATOON last edited by
      Hello, I am using a BL Touch on my Ender 5 Plus. When I home the Z-Axis, the bed moves up but then stops and the printer says failed to enable endstop. How do I fix this. The BL Touch is wired properly and it goes through its start-up procedure.
      ; homez.g
      ; called to home the Z axis
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Sat Apr 30 2022 22:44:38 GMT-0700 (Pacific Daylight Time)
      G91 ; relative positioning
      G1 H1 Z-355 F1800 ; move Z down until the endstop is triggered
      G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
      ;G91 ; relative positioning
      ;G1 Z5 F100 ; lift Z relative to current position
      ;G90 ; absolute positioning
      ; homeall.g
      ; called to home all axes
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Sat Apr 30 2022 23:00:17 GMT-0700 (Pacific Daylight Time)
      G1 H1 X285 Y285 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
      G1 H2 X-5 Y-5 F6000 ; go back a few mm
      G1 H1 X285 Y285 F360 ; move slowly to X and Y axis endstops once more (second pass)
      G1 H1 Z-355 F360 ; move Z down stopping at the endstop
        dc42 administrators @TRATOON last edited by
        @tratoon a BLTouch is a Z probe, not an endstop. Homing Z using a Z probe is done differently (using a G30 command) compared to homing using an endstop. See https://docs.duet3d.com/User_manual/Machine_configuration/Configuration_cartesian#homing-z.
        • TRATOON
          @dc42 I fixed it, the code the RepRap Config Tool Generated was incorrect. I had to dig around for the correct code.
          • Topic has been marked as a question  TRATOON TRATOON
          • Topic has been marked as solved  TRATOON TRATOON
