    Maybe Bug: Redoing height maps add sometimes random offsets
    249
    • dgrat
      dgrat last edited by dgrat
      I think this is a firmware bug, I noticed already since a while. It is still present in 3.4.
      When I redo height maps the height maps shift sometimes by a constant amount.
      Here I played with a z-offset of 1.9 mm and 1.95 mm. The offset became quiet drastic (+/- up to 0.5 mm).
      I noticed that behavior on all my printers. This behavior is rather random. Sometimes the height maps are fine.
      The trigger height seems always correct and does not change, because the reported z-value upon triggering is always the same value.
      Seems like the firmware is adding a random number to the height estimate.
      After powering off the printer entirely (no reset via firmware), I often get a correct height map again.
      Any ideas?
      Steps to reproduce:
      Duet Wifi 2
      call: G31 P500 X-25.5 Y37 Z1.95
      Example shows a G29 after a print I ended.
      And here just after redoing after soft-reset which disappeared only after head-reset
      dgrat fcwilt 2 Replies Last reply Reply Quote 0
      • dgrat
        dgrat @dgrat last edited by
        This post is deleted!
        • fcwilt
          fcwilt @dgrat last edited by
          @dgrat
          Are you setting the Z=0 Datum using a single G30 are the center of the bed or perhaps at one of the grid points?
          You have to do that when creating the height map and when loading the height map.
          dgrat 1 Reply Last reply Reply Quote 0
          • dgrat
            dgrat @fcwilt last edited by
            @fcwilt
            I thought that is only necessary before starting a print?
            Where is written that G29 requires that and why the offset changes?
            bricor 1 Reply Last reply Reply Quote 0
            • bricor
              bricor @dgrat last edited by
              @dgrat
              https://docs.duet3d.com/User_manual/Connecting_hardware/Z_probe_mesh_bed
              Partway down under the heading:
              Running bed mesh compensation
              Establish a Z=0 datum
              dgrat 1 Reply Last reply Reply Quote 1
              • dgrat
                dgrat @bricor last edited by
                @bricor
                I wonder if G29 depends on another command e.g. g30 to create a datum.
                Shouldn't be heightmap creation defined in a gcode macro which the user defines?
                Stephen6309 fcwilt 2 Replies Last reply Reply Quote -1
                • Stephen6309
                  Stephen6309 @dgrat last edited by Stephen6309
                  @dgrat I use this for my mesh.g file, it makes sure the printer is homed, and load the heightmap.csv, if it doesn't exist, creates it:
                  while iterations < #move.axes & move.axes[iterations].visible
                  	if !move.axes[iterations].homed
                  		G28
                  		break
                  M290 R0 S0    ;  clear baby stepping
                  G29 S1
                  if result > 1 ; if no heightmap.csv, make one
                  	G29 S0
                  • fcwilt
                    @dgrat said in Maybe Bug: Redoing height maps add sometimes random offsets:
                    @bricor
                    G29 executes mesh.g if it exists, as it should.
                    The assumption is that mesh.g contains all the commands needed to create the desired height map.
                    And since you need to set the Z=0 Datum before creating/loading a height map mesh.g likely is going to include a G30 to set the Z=0 Datum.
                    Now some folks who home with a Z probe rely on that to set the Z=0 Datum. I simply include the G30 in the mesh.g file so I don't have to concern myself with what came before. Also mesh.g is going to work at the current bed temperature which might be different from the bed temperature when homing.
                    dgrat 1 Reply Last reply Reply Quote 2
                    • dgrat
                      Thanks all for gcode and explanation
                      fcwilt 1 Reply Last reply Reply Quote 0
                      • fcwilt
                        Always glad to help if I can. If I cannot help I try very hard to not make things worse. 😉
