    G-code for only "Filament Extrusion" without moving nozzle
    3D Printing General Chat
    1.1k
    • Asif Istiakundefined
      Asif Istiak
      I need to extrude filament in a fixed amount for a certain time by the 3D printer without moving the nozzle to any axis.
      I have applied the code like this(mentioned below) but as soon as I run the code, the nozzle stops.
      What's the problem with my code?
      Is there any instance of a modified G-code to meet my need?
      Thanks in advance.
      Code-
      G21 ; set units to millimeters
      M104 S200 ; set temperature
      M106
      M109 S200 ; wait for temperature to be reached
      G90 ; use absolute coordinates
      G92 E0
      M82 ; use absolute distances for extrusion
      G1 Z0.0 F5.000
      G1 Y1.000 E0.0100000
      G1 Y1.000 Z0.00 E1.00000 F2.000
      G1 Y0.000 Z0.00 E1.00000 F2.000
      G92 E0
      M107
      M104 S0
      M107
      G91
      G90
      BoAundefined 1 Reply Last reply Reply Quote 0
      • BoAundefined
        BoA @Asif Istiak
        @asif-istiak M82 seems to be a problem here - use M83 instead. Also why involving other axes that the one You want to move? G1 E1.0 F2.0 should be fine.
        • BoAundefined BoA referenced this topic
