G-code for only "Filament Extrusion" without moving nozzle
@fcwilt I see. thanks a lot for your explanation
@asif-istiak said in G-code for only "Filament Extrusion" without moving nozzle:
If all you want to do is extrude some filament, then this can be much simpler.
G21 ; set units to millimeters
This G21 is usually set in config.g so will be loaded when the printer is turned on. Unless for some unknown reason you are working in inches and have G20 instead of G21 in your config.g file.
M104 S200 ; set temperature
M104 is deprecated so you ought to use G10 instead.
M106
Do you really need to turn on the part cooling fan? If not, this command can be omitted.
M109 S200 ; wait for temperature to be reached
This command is also deprecated so you ought to use M116 instead.
G90 ; use absolute coordinates
As you are not moving X,Y or Z, this G90 is irrelevant and can be omitted.
G92 E0
This will zero the extruder when it is set to absolute extrusion using M82, but in the following command, you use M83 to set the extruder to relative mode. Therefore you don't need this G92
M83
G1 E12.00000 F2.000
Those commands will do want you want except that you don't need to add all those zeros.
G92 E0
Again, this will zero the extruder when it is in absolute mode but you ae using relative so it is irrelevant and can be omitted.M107
This will turn off the part cooling fan but as above, why do you need to turn it on if you are not printing a part?
M104 S0
This will set the extruder temperature to zero but again, because it is deprectaed, you ought to use G10 instead.
M107
This turns the fan off yet again - you don't need do it twice.
G91
This sets relative positioning for XY and Z bt you are not moving them so it isn't needed.
G90
Finally, this sets XY and Z back to absolute so can also be omitted.
So you code could be as follows:-
T0; set tool zero - it it's likely that you only have one tool and you already have a T0 command in your config.g but it's best to be safe
M83; use relative extrusion (if this is already set in config.g, it can be omitted
G10 P0 S200 ; set tool to 200 degC
M116; wait for temperature to stabilise
G1 E12 F2; extrude 12mm of filament at 2mm/sec
G10 P0 S0; set tool temperature to zero. -
@deckingman Thanks a ton, sir
