    40mm heatsink fan mount (when using part cooler)
    • Jimborr
      Jimborr last edited by
      I couldn't find any 40mm heatsink fan mount that worked when using the part cooler.
      30mm fans are too loud for my taste.
      I'm currently remixing one now. I have a working one running on the printer now but
      I'm not too pleased with the fiting, it's a bit loose. Mostly doing this by trial and error
      since designing parts isn't my best skill.
      Both models below require the spacer between pcb and heatsink, however I've made it only 2mm thick which
      seems to work nicely.
      Current iteration that I'm printing for testing right now.
      http://a360.co/2xFPFyh
      Currently mounted and working, but not near perfect.
      http://a360.co/2kOg2km
      If there is a working solution for this I'd be very happy to see it.
      • Jimborr
        Update part, no longer require the 2mm spacer.
        https://www.thingiverse.com/thing:2587036
        • Jarery
          Jarery last edited by
          Looks good, i'll give it a shot net week
          • Jimborr
            I could probably make it a 1mm shorter before the angle and shave of a millimeter or two from the fan mount side..
            It sticks out about 1-2mm more than the part cooler, measured on the "long side".
            • Jimborr
              I've updated the thingiverse part, added a model where I removed about 2mm from the fan mount thickness.
              Not printed it yet, but should work fine.
