    Thermostatically-controlled fan
    • agusanoundefined
      agusano
      I need help for a project that I am carrying out.
      I am using the output of a fan to drive a solid state relay. This relay activates or turns off some LEDs that do not have to be on all the time. That's why I need to have control over its on and off.
      If the leds get too hot they can cause an emergency.
      I have chosen to use the thermostatically controlled fans. I bought the board to be able to use a thermocouple. I have managed (using a fan to see it graphically) that it turns on from a specific temperature. But I would like it to work the other way around: that when the sensor measures a temperature higher than a limit value, the FAN OUTPUT TURNS OFF.
      Could that be possible? Thank you
      cosmowaveundefined 1 Reply Last reply Reply Quote 0
      • cosmowaveundefined
        cosmowave @agusano
        @agusano Which FW Version are you using?
        Eventually you can invert it with a leading "!" in the M950 command
        M950 F2 C"!Fan2" Q25000
        Mankati FSXT+, DeltaTowerV2, E3D MS/TC
        agusanoundefined 1 Reply Last reply Reply Quote 2
        • agusanoundefined
          agusano @cosmowave
          @cosmowave I'm using RepRapFirmware for Duet 2 WiFi/Ethernet 3.2.2 (2021-02-11).
          The fact is that i want to use this as a safety disconection system.
          I want to do something like this:
          M106 P0 H0 T70; Send this gcode to power up the LEDs but when the sensor measures 70º to force it to stop working.
          In case that the system is working properly i will use the M106 P0 S0 command to turn of the relay.
            cosmowave @agusano
            @agusano Then, i think the best option would be to create and use daemon.g for controlling the LED's.
            agusanoundefined 1 Reply Last reply Reply Quote 0
            • agusanoundefined
              agusano @cosmowave
              @cosmowave @cosmowave I will study this option.
              But what worries me the most is that i want to implement this safety system because once i send this m106 p0 s255 gcode to power the leds. If the software that i use to print or my board bugs i can't manage to send the power off gcode on time. Thats why i wanted to control the temperature the led reaches once i turn them on. In that moment is when i want to control that and when it reaches hight temperature (because something on the software/board went wrong) i can turn them of without damaging anything.
                cosmowave @agusano
                @agusano If you'd like to be completely safe, you should consider to design a "power cut" circuit
                It is possible to make a circuit with your temp sensor, a transistor and some resistors to cut the power supply of the LED's when a temp is reached.
                Eventually there are complete circuits to buy on the market. Like a relais wich is controlled by a temp sensor...
