    CAN command glossary?
    • acmeanvilundefined
      acmeanvil
      Hi there,
      I have been part of developing a CAN-FD enabled machine pendant at work for something unrelated to a 3d printer, but seems like it would be cool if it could also be attach to my home duet 3 setup. Which leads to two questions 1) does the current duet setup allow for a pendant be attached to the CAN bus to send commands to a duet 3 6HC which it could execute across expansion and tool boards and if so 2) is there a syntax/command library out there that?
        dc42 administrators @acmeanvil
        @acmeanvil RRF doesn't yet support sending GCode commands to a main board over CAN. We've considered supporting it in the past for use by our test equipment, and we may do so in a future version.
        acmeanvilundefined 1 Reply Last reply Reply Quote 1
          acmeanvil @dc42
          @dc42 Thanks for the quick reply David I will keep an I out for it.
