    can we use heater pin on Duet Expansion Breakout Board
    • Akds48undefined
      Akds48
      As on expension board we have HEater PWM so can we use these PWM pin for heating up the extruder?
      if yes then please suggest how can we do?
        droftarts administrators @Akds48
        @akds48 Yes, but you cannot use the heater PWM pin directly, as the output is only 3.3V 5V and for signalling. It can control a MOSFET (eg like the MOSFET board sold with the E3D Super Volacano https://e3d-online.com/products/supervolcano-80w-heater) or Solid State Relay, which would allow you to connect a higher voltage (eg 12-24V) to your heater. Note that signal is inverted on the heater PWM pins on the Expansion Breakout Board (and DueX); see https://docs.duet3d.com/Duet3D_hardware/Duet_2_family/Duet_Expansion_Breakout_Board#using-the-servo-headers.
          The signal level on the PWM output pins on Duet expansion boards is 5V, not 3.3V.
