    DuetAPI.xml not included in RC files
    Duet Web Control
      jay_s_uk
      DuetAPI.XML isn't included in RC releases and is only part of the combined Duet2and3Firmware file yet it is required by the ObjectModel plugin. Would it make more sense to package it as part of DuetWebControl.zip @chrishamm ?
      I only noticed as I was setting a new machine up and went directly to the 3.4.1-RC1 and DuetAPI.XML was missing.
      • chrishammundefined
        chrishamm administrators @jay_s_uk
        @jay_s_uk I already added it to the upcoming release candidate 2 so no worries. In a future version (3.5) I may change the build script to add it automatically; at present I always have to add it manually after building, so sometimes I happen to forget that step.
        The object model changes since 3.4.0 were pretty marginal, so the OM explorer should continue to work fine for most keys. The OM plugin won't crash if it fails to find a certain key either.
        Duet software engineer
