    Echo commands...
    1.6k
    • Nightowlundefined
      Nightowl
      I would like to add an echo command to my pauge.g file to indicate what the value of a specific global variable is, in this case the saved spindle speed.
      Assuming the global variable is named "savedSpindleSpeed" and has the value "x", would the syntax of this echo command be correct, please:
      Echo "Spindle speed saved at " ^ savedSpindleSpeed ^ "RPM"
      Thank you.
      Few things are more dangerous than taking the advice of someone who thinks he knows what he's doing.
      I'm still on my learning curve, so take everything I say with caution!
      RatRig 1075, Duet3 MB6HC, Sorotec SFM 1000 PV-ER milling motor, Hobbyist
      • fcwiltundefined
        fcwilt @Nightowl
        @nightowl999 said in Echo commands...:
        Thank you.
        I'm using firmware v3.40 for this test and this works:
        echo "Spindle speed saved at " ^ global.savedSpindleSpeed ^ " RPM"
        or
        echo "Spindle speed saved at " ^ { global.savedSpindleSpeed } ^ " RPM"
        To access the value in a variable you need to prefix the variable with global. or var. as appropriate.
        Typically you need to enclose the entire name with { and } but that doesn't seem to apply with echo which seems to work with or without the { } characters
        I find the syntax for accessing variables confusing at times.
        Nightowlundefined 1 Reply Last reply Reply Quote 1
        • Nightowlundefined
          Nightowl @fcwilt
          Once again, @fcwilt, you've come to my assistance.
          Thank you!
          • Nightowlundefined
            Nightowl @Nightowl
            @fcwilt
            The second example works for me, but not the first one, for some reason.
            Never mind though, it's good enough!
            Thanks again 👍
            dc42undefined 1 Reply Last reply Reply Quote 1
              dc42 administrators @Nightowl
              Both should work. You can also use this, which is slightly more efficient because it avoids constructing the entire string:
              echo "Spindle speed saved at", global.savedSpindleSpeed, "RPM"
              Values in an echo command that are separate by comma are printed successively with one space character inserted between them.
              • mikeabuilderundefined
                mikeabuilder
                DC42's method is shorter for using echo, but does not concatenate strings in general. If you want to do something like an M291 (print a message to the user interface, maybe wait for a response) vs sending the output to the console, concatenate with a caret" is needed.
                Nightowlundefined 1 Reply Last reply Reply Quote 2
                • Nightowlundefined
                  Nightowl @mikeabuilder
                  @mikeabuilder said in Echo commands...:
                  Thanks, Mike (assumption made, sorry if I'm wrong).
                  The echo sample provided by @dc42 works as I need it to, but you've raised an interesting point (for me, anyway) about the versatility of the Duet3 and it's software.
                  I think I'll incorporate something like the M291 command, but is there a way to do something other than (essentially) just Resume or Cancel? A simple example would to prompt the user to move to a specific point (defined in a "startpoint.g" file, let's say) after initial homing has completed?
                  deckingmanundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                  • deckingmanundefined
                    deckingman @Nightowl
                    Yes, you can do pretty much anything you want with macros and/or conditional gcode. Pause.g, resume.g and cancel.g are just some examples of macros, (as are all the homing files and much more). So yes, you can create a macro called "startpoint.g" to move to a specified point and run that either stand alone, through the console, via an external trigger, or by calling it at the end of your home all macro.
                    • fcwiltundefined
                      fcwilt @Nightowl
                      If you use M98 P"some_optional_code.g" to invoke a file, the code in that file can be executed or not by using a M291 with S3.
                      If you select CANCEL the rest of the code in that file, after the M291, will not be executed.
                      If you select OK the rest of the code in the file will be executed.
                      In either case execution will then continue after the M98 P"some_optional_code.g".
                        mikeabuilder
                        @Nightowl999, as @fcwilt, says, the m291 is the only input method you can use, but RRF continues to expand, so additional options may show up in the future. With OK and cancel, it is possible to capture which answer the user gave. I wrote a little macro named "OK_CANCEL_checker.g" that can be called with
                        M98 P"<dir>/OK_Cancel_checker.g" S"Select OK for <option 1> and Cancel for <option 2>"
                        The S parameter is for the message you want displayed in the message box. When you want user input, call the macro. After the user answers and execution returns to the main macro, the value of a global variable is either "CANCEL" or "OK". You code can then branch based on the value.
                        Here's the full macro
                        ; Macro to be called from other macros to let user select one of two options (OK and Cancel)
                        ; PARAMETERS
                        ;     S =  Message to be displayed
                        ;     R =  any value. If included in parameter list, will return a random choice of OK or CANCEL without user interaction.
                        ;          used for debug of calling programs.
                        ; RETURN
                        ;   Global.OK_CANCEL is set to "OK" or "CANCEL"
                        ; USAGE
                        if !exists(global.OK_CANCEL)
                          global OK_CANCEL = "NO MESSAGE"
                        else
                          set global.OK_CANCEL = "NO MESSAGE"
                        ;Check for parameters
                        if !exists(param.S)  ; see if a parameter was provided
                          M291 P"Message parameter not provided. "  S0 T5   ; S0 means no buttons, t5 means wait 5 seconds and move on.
                          M99
                        if exists(param.R)  ; see if a random response is requested instead of user action
                          set global.OK_CANCEL = "OK"
                          if random(100) > 50
                            set global.OK_CANCEL = "CANCEL"
                          M99                  ; return without asking for user interaction.
                        M291 P{param.S} S3 T-1
                        M99
                        fcwiltundefined Nightowlundefined 2 Replies Last reply Reply Quote 1
                        • fcwiltundefined
                          fcwilt @mikeabuilder
                          @mikeabuilder
                          Nice idea.
                          A boolean variable would be a bit easier for the calling code to check the result.
                          • Nightowlundefined
                            This is great, thank you @mikeabuilder.
                            Not only does it help me, but it gives an insight into how code works.
                            Is there a guide or tutorial somewhere, where I can start to learn this stuff for myself, please? I appreciate there is guidance with some examples of gcode and meta commands on the Duet pages, but I'm hoping to learn more.
                            I used to program with Microsoft Visual Basic for Applications many years ago, but I imagine the language is quite different now.
                            fcwiltundefined 1 Reply Last reply Reply Quote 1
                            • fcwiltundefined
                              fcwilt @Nightowl
                              I use quite a few code files beyond the common ones. Here is a set from one of my printers:
                              Feel free to ask any questions you may have about the "programming" features of the Duet firmware - version 3.4.x plus BtnCmd 0.10.09 can do some rather amazing things compared to the Duet firmware 2.x I started with a few years back.
                              Nightowlundefined 1 Reply Last reply Reply Quote 0
                                mikeabuilder
                                @fcwilt - I did start with a boolean variable, but the first time I used it I had to look to remember if "OK" was true of false. The second time I looked it up, I switched it to "OK" and "CANCEL" so I would not need to look it up again.
                                @Nightowl999 - The programming capability these folks are building into RRF (and I believe it if these few folks) is a relatively new capability and is very simplified. You will not find anything as fancy as what you learned in VB. It was primarily developed to support the "gcode everywhere" philosophy. Additional features may be added, but I would not expect a full-blown programming language.
                                Having said that, the meta command page in the wiki (https://docs.duet3d.com/en/User_manual/Reference/Gcode_meta_commands) really does describe all the capabilities. Beyond that, it's clever folks building macros. But here's my nuggets of RRF gcode programming wisdom.
                                • You use G codes and M codes in your macros to "send" things to the machine.
                                • You use the object model (https://github.com/Duet3D/RepRapFirmware/wiki/Object-Model-Documentation) to read things from the machine that you might use a G or M code in the console to see in the user interface. You can "never" set a value to a variable by setting it equal to am M or G code.
                                • Understanding what is and is not a "code block" is important because a variable created inside a code block is only available to itself and it sub-blocks (child blocks) not it's parent. Return to this when you get an error saying a variable does not exist when you know darn well you created it.
                                • It seems easiest to just make everything a global variable, but these take up memory space and are never deleted, except a power on or reset. So you can clog up the memory with too many. Best to use local variable wherever you can. Those are destroyed and the memory freed up for other uses as soon as the code block where they were created is finished being run.
                                • Carefully read and practice the echo, particular the echo >filename and echo >>filename. These are your ticket to having your macro write something to a file that you can read later.
                                • So far, there is not command for reading a file, making arrays, parsing strings, or collecting generalized user input. In my opinion, these things are slippery slopes to a mountain of work for the developers and they have been wise in approaching them with extreme caution.
                                infiniteloopundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                                • infiniteloopundefined
                                  infiniteloop @mikeabuilder
                                  @mikeabuilder
                                  So far, there is no command for reading a file
                                  In a sense, there is: you can execute the file as a macro. This includes the ability to establish or modify global variables, to execute GCodes with parameters having been calculated at file creation time, to inspect the object model, and to run conditional code.
                                  At least, this gives us the ability to store data, instructions and conditions - and to handle them when we "read" the file (calling it as a macro). This is different from the common idea of keeping data and code distant, but apart from string handling and a user interface in excess of M117 and M291, we have all the tools to control our machine by means of writing and reading states and conditions. Think different 😊
                                  • fcwiltundefined
                                    Good to know.
                                    But for the record OK is always True and CANCEL is always False. 😉
                                    I notice you check for the missing message parameter. Any reason you did not simply abort if missing?
                                    • Nightowlundefined
                                      Nightowl @fcwilt
                                      @fcwilt
                                      I'm thinking I might configure a 'working' page specifically for CNC users with @MintyTrebor's BtnCmd add-in, but I need to get my head around what I need to see before I do that.
                                      Unlike you 3D printer guys, I really don't have an interest in temperatures, hot ends, fans, beds, heaters, etc., just a few progress indicators, pause, resume, stop and PANIC!! buttons, is all 🙂
                                      • Nightowlundefined
                                        Nightowl
                                        One thought. In VBA you can hover the mouse icon over a declared variable and it will show it's value in a ToolTip. I'm not asking for that here (I don't think this system is complex enough to warrant that) but is there a way of finding the value of a variable in the code sender, or is it only in the Object Model (if at all)?
                                          mikeabuilder
                                          @infiniteloop - regarding writing a file that contains gcode that will put values into variables when it is executed. That's brilliant! Love it. The user (me) will need to be careful about managing global and local variables so as to not use up all the memory. I'm already envisioning an array.g for simple arrays.
                                          @fcwilt - true (or should I say "OK") about OK always being true, but that's another thing to remember and my brain is nearly filled to capacity. I pop up a user message if there is no message parameter supplied just to help me during debug - but it is redundant with returning "NO MESSAGE" in the global variable.
                                            Well, in some cases macros can replace a global variable completely. That's not true for state and conditional checks during runtime, but why not put some parameter for a Gcode into a macro - together with the Gcode? As additional benefit, these "data" survive loss of power (and earthquakes as well).
