    Issues with connecting to browser.
    Duet Web Control
    1
    • Braeden 0undefined
      Braeden 0
      Hello, I've been using my Duet2 Ethernet for some time now, but it just now started messing up when I go to connect to the browser. It's been doing fine, but after a print, I tried to go to the tab that had the control thing open, and it said that it couldn't establish to the server. All of my other printers are working with the Duet web control but this one isn't. It has a mDNS name "sterope". The difference between this and the others are that this one I have to type in "sterope.local" into my browser to access it. The others I copied and pasted the IP to the browser tab. I tried the M552 s0 then M552 S1 P0.0.0.0 to reset it but it said the actual IP was 0.0.0.0. With the others when I do that it gives me a knew IP address, 192.108.57.8 or something like that for the actual IP address. Sterope gives me 0.0.0.0. Thank you in advance.
      Braeden 0undefined 1 Reply Last reply Reply Quote 0
        Braeden 0 @Braeden 0
        @braeden-0 Nevermind the issue was my router. 🙂
