    Homebuilt heatbed/heating issues
    447
    • Stephen6309undefined
      Stephen6309 @Nvigr8
      @nvigr8 IR thermometer will not show the correct temp on shiny aluminum. Put a piece of black tape on the bed to read from. Or, use a thermal couple.
      Insulating the bed on the bottom will help.
      Nvigr8undefined 1 Reply Last reply Reply Quote 0
      • Nvigr8undefined
        Nvigr8 @Stephen6309
        @stephen6309 Thanks for the reply. I have a flexible build plate on top of the aluminum. It is textured but a little shiny. I'll take the temp again with it off.
        I do have the underside fully insulated. Forgot to put that in the specs.
        Modified Multoo MT1.5, Modified Creality CR6SE, Modified Monoprice Mini Delta, Modified Wanhao Di3, Phrozen Shuffle
        • infiniteloopundefined
          infiniteloop @Nvigr8
          @nvigr8 You say the heat pad has an inline temp. controller: how is this specified? In your gCode snippet, you declare it as a thermistor with a resistance of 100k at 25°C (T parameter) and a beta value of 3950 (B parameter). This will eventually be correct, but to be sure, check the specs.
          Assuming that the thermistor reports proper values, these are the readings from the heater itself. It takes some time until the heat propagates through your aluminium plate, it is an inertial system. As you have an insulated underside, the heater will reach the required temperatures very fast - and stop there, feeding no more heat to the aluminium plate.
          It takes a long time until the bed’s surface will reach the requested temperature - 10-20 minutes can be realistic, assuming your thermistor’s parameters are correct. Even then, the thermistor can be up to 10°C off.
          You can improve the situation by adding a second thermistor: drill a hole into the side of your bed plate and glue the thermistor in there - its readings should give you a better idea of the temperatures at the surface.
          • Nvigr8undefined
            Nvigr8 @infiniteloop
            @infiniteloop Thank you for the reply. My apologies, I should have clarified. I removed the plug and controller from the heatpad and connected it to the mains on the powersupply and use the Duet board as the controller. Not sure if that makes a difference in regard to your comments.
            I agree, moving the thermistor would be much more accurate. I see your point about having it next to the insulated pad. I will do that next. Is there preferred thermistor type here for this situation/?
            infiniteloopundefined 1 Reply Last reply Reply Quote 0
              @nvigr8 said in Homebuilt heatbed/heating issues:
              If you've done it as described in your OP: no.
              Is there preferred thermistor type here for this situation?
              Take a bead type thermistor with 100k and a known beta value.
              Nvigr8undefined 2 Replies Last reply Reply Quote 0
              • Nvigr8undefined
                @infiniteloop Thanks. I'll give that a try.
                • Nvigr8undefined
                  @infiniteloop I have a Semitec 104GT-2 from an E3D hotend on hand. Any reason that won't work?
                    AFAIK that's no bead type, so you must look how to apply it to your bed plate (with good thermal contact). From the data sheet, I read it to have a beta value of 4267 - that would be the B parameter of M308.
                    • Nvigr8undefined
                      @infiniteloop If can find a drillbit that's close to the diameter of the cylinder that the thermistor head is in, it should fit nicely in with a little thermal paste and a screw placed near the hole so the head overlaps slightly to keep it from coming out. I think...
                        @nvigr8 Sounds reasonable. Good luck!
