    5-axis cnc machine using duet2 wifi
    1
    89
    • spamboyundefined
      spamboy
      Re: 5-axis kinematic firmware
      I was planning to use 5 instead of 3 stepper motors for my project using duet2 wifi board. How should I configure it ?
      Also while reading through the old threads, I came across the term "Slicing Software" and Im not aware about it. Could you please explain what it really is and what makes it so difficult without that ?
      If we have provision for 5 connections, then it should have been easy to driver two additional steppers by specifying our coordinates right ? And since this board is quite new to me i would really appreciate it if you could suggest whether I can connect GPIO pins on duet 2 with my own stepper driver and run it using PWM ?
      Thanks in advance 🙂
