removing a warning height map message
@sebxtreme You have G29 S1 in config.g, remove it.
In theory, if your delta homed height is set perfectly, it should give the same Z0 result as the probe (assuming it's trigger offset is also set accurately), but it's far easier to just let the probe dictate the bed position.
@phaedrux yes the G30 give the same height of my config each time . many thanks.
