    Can not connect to DWC
    Duet Web Control
    • anaghundefined
      anagh
      Hello everyone,
      When I try to connect to the controller through DWC, this is the error message I get: Connection interrupted, attempting to reconnect. Cannot set properties of undefined (setting "spindle").
      Any suggestions?
      M122 output
      RepRapFirmware for Duet 3 MB6HC version 3.4.0 (2022-03-15 18:57:24) running on Duet 3 MB6HC v1.01 or later (standalone mode)
      Board ID: 08DJM-956BA-NA3TN-6J1FD-3SN6T-KA8AV
      Used output buffers: 1 of 40 (12 max)
      Static ram: 151000
      Dynamic ram: 94812 of which 0 recycled
      Never used RAM 102004, free system stack 192 words
      Tasks: NETWORK(ready,26.8%,251) ETHERNET(notifyWait,0.1%,168) HEAT(notifyWait,0.0%,321) Move(notifyWait,0.0%,352) CanReceiv(notifyWait,0.0%,944) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,333) TMC(notifyWait,7.9%,92) MAIN(running,65.2%,1273) IDLE(ready,0.0%,30), total 100.0%
      Owned mutexes: USB(MAIN)
      Last reset 00:08:49 ago, cause: power up
      Last software reset at 2022-06-01 15:27, reason: User, GCodes spinning, available RAM 105332, slot 0
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
      Error status: 0x00
      Step timer max interval 130
      MCU temperature: min 27.8, current 41.0, max 41.1
      Supply voltage: min 36.4, current 36.4, max 36.5, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.1, current 12.2, max 12.3, under voltage events: 0
      Heap OK, handles allocated/used 99/3, heap memory allocated/used/recyclable 2048/42/0, gc cycles 0
      Events: 0 queued, 0 completed
      Driver 0: standstill, SG min 0, mspos 8, reads 62951, writes 14 timeouts 0
      Driver 1: standstill, SG min 0, mspos 8, reads 62951, writes 14 timeouts 0
      Driver 2: standstill, SG min 0, mspos 8, reads 62952, writes 14 timeouts 0
      Driver 3: standstill, SG min 0, mspos 8, reads 62952, writes 14 timeouts 0
      Driver 4: standstill, SG min 0, mspos 16, reads 62952, writes 14 timeouts 0
      Driver 5: standstill, SG min 0, mspos 16, reads 62952, writes 14 timeouts 0
      Date/time: 2022-06-01 16:17:32
      Slowest loop: 5.33ms; fastest: 0.05ms
      === Storage ===
      Free file entries: 10
      SD card 0 detected, interface speed: 25.0MBytes/sec
      SD card longest read time 2.6ms, write time 0.0ms, max retries 0
      DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      === AuxDDARing ===
      Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is ready with "M122" in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty
      === CAN ===
      Messages queued 4763, received 0, lost 0, boc 0
      Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 2647/0/0
      Tx timeouts 0,0,2646,0,0,2115 last cancelled message type 30 dest 127
      === Network ===
      Slowest loop: 5.26ms; fastest: 0.02ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions
      HTTP sessions: 1 of 8
      • Ethernet -
        State: active
        Error counts: 0 0 1 0 0
        Socket states: 5 5 2 2 2 0 0 0
        ok
        What do you have in your config.g?
        How did you update to 3.4?
        anaghundefined 1 Reply Last reply Reply Quote 0
        • anaghundefined
          anagh @Phaedrux
          @phaedrux Quick update: I did the whole setup from scratch using the latest (stable) versions for the firmware and DWC. That seems to have fixed the issue.
