    Include variable in heightmap.csv filename
    Gcode meta commands
    • MaxGyverundefined
      MaxGyver
      I am working on a script that runs the mesh bed probing routine at increasing temperatures, but I have problems saving the heightmap.csv after each loop.
      I have a variable called "var.temp". It increases by 10° for each cycle until a set temperature is reached.
      I would like to save the hightmap.csv file at the end of each cycle with the value of "var.temp" included in the filename. So when var.temp = 100 the file should be named "heightmap_100°C.csv"
      But I can't get it to safe correctly using G29 S3.
      I know that the code below will not work like this. It is only meant to illustrate what I am tying to do.
      var temp = 100
      G29 S3 P"heightmap_{var.temp}.csv"
      Some help would be much appreciated 🙂
      • MaxGyverundefined MaxGyver marked this topic as a question
      • fcwiltundefined
        fcwilt @MaxGyver
        @maxgyver
        Here is from my code:
        G29 S3 P{var.name ^ ".csv"} ; save heightmap again with file name based on mesh settings
        This should work for you:
        G29 S3 P{"heightmap_" ^ var.temp ^ ".csv"} ; save heightmap again with file name based on mesh settings
        MaxGyverundefined 1 Reply Last reply Reply Quote 1
        • MaxGyverundefined
          MaxGyver @fcwilt
          @fcwilt said in Include variable in heightmap.csv filename:
          Yes it does!
          Thank you very much
          -Max
          • MaxGyverundefined MaxGyver has marked this topic as solved
