    Object Cancel Plugin 1.1.0
    Plugins for DWC and DSF
    • Sindariusundefined
      Sindarius
      There is a new version of the object cancel plugin updated for DWC 3.4.1
      Available at
      https://github.com/Sindarius/ObjectCancelPlugin/releases/tag/1.1.0
      Adamfilipundefined 2 Replies Last reply Reply Quote 5
      • paralepsisundefined paralepsis referenced this topic
      • Adamfilipundefined
        Adamfilip @Sindarius
        @sindarius Thank you for the update.
        Is the proper procedure to pause the print, then cancel object then resume print?
        Sindariusundefined 1 Reply Last reply Reply Quote 0
          @sindarius I have installed the plugin with
          Board: Duet 2 WiFi (2WiFi)
          Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.1 (2022-06-01)
          Duet WiFi Server Version: 1.26
          I am using SuperSlicer 2.4, when I open up the plugin page. I see 8 rows, the bottom 4 have names. the top 4 dont. My job only has 4 objects. curious why 8 rows are shown, is this something i can fix with my setup?
            Sindarius @Adamfilip
            @adamfilip If you open the Object Model plugin and look at Job -> Build -> Objects do 4 items appear in the list or 8? This is where the plugin is getting its information.
              @adamfilip There is no need to pause to cancel
              • blt3dpundefined
                blt3dp
                Curious if this would also work with RRF & DWC 3.4.0 and if it supports circular beds (Delta) and 0,0 location in the center.
                Edit: Looking at the code, looks like it is aware of a Delta's bed being circular.
                My 3D Printing YouTube Channel
                Better Living Through 3D Printing
                Follow me on Instagram and Twitter
                Instagram
                Twitter
                  Sindarius @blt3dp
                  @blt3dp while I do not have a delta to test with I do try my best to make sure that deltas are supported just like in the G-Code Viewer.
