Mobile Phone Web control Issue
Hi, I have a small problem when using Web control on phone.
I can't change any of the heaters active temperature by writing it in and pressing ENTER, I can change it for standby temperature by doing this but not for active. The only way to change active is to use already provided temperatures from the drop down menu. Is there something I can do to change this? Or can I at least add my own temperatures to the drop down menu?
Edit: Btw Im using the latest firmware -
@humbleone said in Mobile Phone Web control Issue:
3.4.1? Is DWC also updated?
What web browser and phone version?
@phaedrux I was using 3.4.0 both firmware and DWC, using Google Chrome and also tried Brave on Android 9 (Phone is Honor Play running on EMUI 9). I just updated to 3.4.1 and the problem still remains. I could try other browser apps if you think its browser related
I would think Chrome would be capable. Perhaps one for @chrishamm to comment on.
@phaedrux Now that I updated it I cant even change standby temperature anymore with keyboard
@humbleone It looks like the key events are triggered differently in Chrome and Firefox (Mobile) vs. Chrome on Android. I prepared new test builds which should fix that, use the SD build if you are in standalone mode or the SBC build if you are in SBC mode. To install it, upload the right file on the Files -> System page.
@chrishamm It works!!! Thanks, you are a true magician
Can I use this version in future firmware updates if I will have same issue? -
@humbleone Thanks for confirming. Future DWC versions will contain the fix, too, so no need to worry about updating.
