    50 way cable
    • buttabeanundefined
      buttabean
      I was looking on amazon and other resellers for a slightly longer cable to connect the duex 2 to the duet wifi. I came across a 50 pin scsi cable. Will that work correctly?
      https://www.amazon.com/PC-Accessories-Connectors-2-Pack-Internal/dp/B01EHFABQG/ref=sr_1_1?s=industrial&ie=UTF8&qid=1508269882&sr=1-1&keywords=50+pin+ribbon+cable
        In principle yes, however 18" is too long. You can make your own cables up from the IDC connectors and ribbon cable if you have a vice, you just need to line the jaws with something soft.
          buttabean
          sweet, thanks. Getting close to finishing my kossel build
          • jlegereundefined
            jlegere
            what would be the maximum recommended length?
