Fuse burned
Hello friends Here is what happened to me the fuse burned and the Z motor socket also burned, do you have any idea of the problem I have? Thank you in advance for your help.
@sgk probably a short or miswiring somewhere. Hard to go into details without knowing more about your setup.
Wow, that's a melted fuse. I assume this is a clone board (some details in the photos imply it is), so its hard to say whether its a manufacturing defect or whether you did cause a surge by shorting something or miswiring the board. The Duet2 wifi board takes up to 25V DC in VIN and the fuse is rated at 15A ... but if that blows just at 15/16A it doesn't melt off like that.
A view of the back of the board to see if there is something shorting it out on the back would also be interesting to see.
you can see on the back photo that not only did the fuse melt, but also the board discolorized and the solder seems to have reflowed a bit where the fuse goes. I have a hard time imagining what could have caused this other than a massive spike from the PSU. What PSU are you using and can you maybe show how the wires that go into the board are connected on the PSU side?
@oliof yes 1 minut
(also the heater wires despite having ferrules look weirdly frizzy, are you sure there was no short just above the ferrules?)
@oliof when I heated the bed to 80d it started to burn
Well either way I would assume there is an issue with your bed heater that caused a massive short. Next to look at would be where the bed wires connect to the bed heater. Many simple printer designs forego proper strain relief there which causes the wires to work harden, then break, and likely short out. So the end of these wires are the next interesting thing to look at.
@oliof yes
@sgk yes?
also, it looks like the PSU was opened and modified in the past ... the yellow sticker is broken that usually warns you about this. At this point I would say you were glad to catch this before it caused a big fire ... but it does not look like a Duet specific issue.
@oliof I just replaced the fan in the power supply with a larger one.
So yeah that PSU is not fit for use anymore, as you lost all warranty on it and its now a liability. If anything happens, you will be personally held responsible.
Can you show the bed wires on the bed side?
@oliof
by account I did not install a mosfet
