Manually adjust temperature
  • We are using a duet wifi/paneldue combo and are struggling to sort out how to manually adjust the temperature of the nozzle when on standby, It heats up fine if printing something, but cannot adjust the temperature.
    I'm guessing we are missing a line or 2 from the config file?
    Here is what we have
    M111 S0 ; Debugging off
    G21 ; Work in millimetres
    M208 X1200 Y2600 Z990 S0 ; Set axis maxima
    M574 X1 Y1 Z1 S0 ; Define active high microswitches
    M584 Z5 ; Apply custom drive mapping
    M569 P5 S0 R1 T2 ; Drive 2 goes forwards
    M569 P4 S1 ; Drive 4 goes forwards
    M350 X16 Y16 Z10 E16:16 I1 ; Configure microstepping with interpolation
    M92 X213.33 Y213.33 Z5000 E418.545:418.545 ; Set steps per mm
    M566 X600 Y600 Z50 E120 ; Set maximum instantaneous speed changes (mm/min)
    M203 X6600 Y6600 Z400 E1200 ; Set maximum speeds (mm/min)
    M201 X100 Y100 Z20 E50 ; Set accelerations (mm/s^2)
    M906 X2000 Y2000 Z2000 E1200 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M143 S260 ; Set maximum heater temperature to 260C
    M140 H-1 ; Disable heated bed
    M302 S0 ; always allow extrusion (disable checking)
    M305 P2 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 2
    M563 P0 D0 H1 ; Define tool 0
    M563 P1 D1 H2 ; Define tool 1
    G10 P1 X0 Y0 Z0 ; Set tool 1 axis offsets
    G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
    M552 S0 ; Disable network
    M106 P1 S1 I0 F500 H1:2 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M106 P2 S1 I0 F500 H1:2 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
  • You can set the room temperature by using M912 S-18.8 (18.8 Is my average between E0 and HeatBed "If you have a heatbed"when I first turn on the system after it hasn't been running) and the paneldue has an option for standbye on print screen. You select your standbye temp then hit the button for extruder 1 and the current temp will turn yellow. Also you can set standby on the web-interface in upperleft hand corner to the right of the current temp. Also You can at anytime type in or select a new temp in current temp on web interface. Also you can hit the title "heater 1" for instance and it will toggle it to on, off, standbye on the web interface.
    I am not sure how to set the standbye for default. I have had to set it everytime.
    The standby temperature is set by the R parameter in the G10 command. However, a heater needs to be turned on before the standby temperature is applied. Here is a possible sequence if you are starting with the tool heater turned off:
    G10 P0 R100 ; set standby temperature of tool 0 to 100C
    T0 P0 ; make tool 0 active without running tool change files
    T-1 P0 ; put tool 0 on standby without running tool change files
    If what you want to do is to set the standby temperatures for a two colour print, just use the appropriate G10 Rxxx commands in your slicer start code.
