    6hc RRF config questions
    Firmware installation
    428
    • rexxundefined
      rexx
      please see photo below
      my question is , which microstepping would i use for a 1.8 degree nema 23.. also a 0.9 degree nema 17
      • rexxundefined
        rexx
        my ABL is my Z stop, do i keep this at none? Even though it is a OPTO switch
        On my Probe type, deploy and retract are triggered by X +/- movements, the rest is OPTO, is this correct when selecting none?
        • rexxundefined
          rexx
          single extruder, single head printer, what needs to go here, as i have no tools on this printer? or is this considered a tool, it is unclear.
          • rexxundefined
            rexx
            what is the best set up for this at home, we do use DWC on a duet 2 (other printer) i would like this to do the same.
            • rexxundefined
              rexx
              With compensation.....Is there anyone available to help me out 1 on 1, remotely? Is this a service you offer, or just through the forum?
              Thank you all in advance.
              Th0mpyundefined 1 Reply Last reply Reply Quote 0
              • Th0mpyundefined
                Th0mpy @rexx
                @rexx I'd be willing to give you a hand. I'll message you privately.
                Usually the team that scores the most points wins the game.
                rexxundefined 1 Reply Last reply Reply Quote 1
                • rexxundefined
                  rexx @Th0mpy
                  @th0mpyGreat Thanks for the offer I have PM you back thanks for the offer
                    dc42 administrators @rexx
                    @rexx said in 6hc RRF config questions:
                    x16 microstepping with interpolation enabled is good in almost all situations. The exception is an extruder with low steps/mm (less than 200) for which x32 or x64 microstepping may be worthwhile.
                    rexxundefined 1 Reply Last reply Reply Quote 0
                    • rexxundefined
                      rexx @dc42
                      @dc42 thanks DC42 IC its optinal i was under the impression 1.8 was ### and .9 was ### steppers total rotational counts
                      what does the enders usualy use for E?
