    Adjusting Z-offset in config?
    • westechundefined
      westech
      This always confused me. I just used baby steps to adjust my first layer. -0.45.
      My config has my Z-offset as Z2.18. So, do I add 0.45 + 2.18 or subtract 0.45-2.18?
      My baby steps lowered the nozzle, but the z offset is the distance between the BL touch trigger and the nozzle. ?
      Thanks.
      fcwiltundefined Stephen6309undefined 2 Replies Last reply Reply Quote 0
      • fcwiltundefined
        fcwilt @westech
        @westech said in Adjusting Z-offset in config?:
        Thanks.
        The Z Trigger Height parameter for the Z probe is the value that is assigned to the logical Z position when the probe triggers.
        A BLTouch probe is going to be within a few mm's of the bed when it triggers but Z Trigger Height parameter could be set to 10,000 and the firmware would happily set the logical Z position to 10,000 - which is clearly nonsensical.
        The firmware is "trusting" that the Z Trigger Height parameter is the correct value.
        If when you jog to Z=0 and you end up not touching the bed the Z Trigger Height parameter is too small.
        On the other hand if you run into the bed while jogging to Z=0 then the Z Trigger Height parameter is too large.
        You take whatever the value is from baby-stepping and subtract it from Z Trigger Height parameter. Of course subtracting a negative number is the same as adding the absolute value of the negative number.
        • westechundefined
          westech
          That answers the confusing part. I added 0.45 to 2.18 = 2.63. And that seemed to work. You have to disregard the negative number.
          Thanks
          • fcwiltundefined
            fcwilt @westech
            Thanks
            Or you can always just subtract the actual number displayed by the baby-stepping, regardless of the sign of the value. The result will be correct.
            • Stephen6309undefined
              Stephen6309 @westech
              @westech Increasing the Z offset gets it closer to the bed, decreasing is farther away. I added this as a comment the the G31, so I wouldn't forget.
