    Redirect output from any command to file
    Gcode meta commands
    • demonlibraundefined
      demonlibra
      Starting with firmware 3.4 the output from an echo command can be redirected to a file.
      Is it possible to redirect output from any command to file or get last output from object model?
      E.g. I write code to get state of TMC registers and want to save result to file.
      var driver_number=0              ; Driver number
      var register_start=0             ; Start (0 ... 127)
      var register_end=127             ; Finish (0 ... 127
      G4 S3
      if (var.register_end<=127) & (var.register_start>=0) & (var.register_end>=var.register_start)
         var counter=var.register_start
         while var.counter<=var.register_end
            M569.2 P{var.driver_number} R{var.counter}
            set var.counter=var.counter+1
            G4 P200
      OwenDundefined 2 Replies Last reply Reply Quote 0
      • OwenDundefined
        OwenD @demonlibra
        @demonlibra
        Assuming you can get the info from the object model..,
        You can use
        echo >"myFile.txt"
        to create the file and then
        echo >>"myFile.txt" "Register",iterations, "=", myVariable
        To append to it.
        Put the former before your loop and the latter inside it
        • OwenDundefined
          OwenD @demonlibra
          @demonlibra
          If you can't get the data from the object model, perhaps try logging
          M929 P"testfile.txt" S3
          while iterations < 10
            M913
          M929 S0
          demonlibraundefined 1 Reply Last reply Reply Quote 1
            demonlibra @OwenD
            @owend Loging work fine. Thank you.
               M929 P"tmcregisters.txt" S3
                  G4 P200
               M929 S0
            2022-06-12 10:00:12 [info] Event logging started at level debug
            2022-06-12 10:00:12 [info] Running: Duet 3 Mini5plus WiFi: 3.4.1rc1 (2022-05-03 09:34:52)
            2022-06-12 10:00:12 [debug] Register 0x00 value 0x000001c0
            2022-06-12 10:00:12 [debug] Register 0x01 value 0x00000001
            2022-06-12 10:00:13 [debug] Register 0x02 value 0x0000000a
            2022-06-12 10:00:13 [debug] Register 0x03 value 0x00000000
            2022-06-12 10:00:13 [debug] Register 0x04 value 0x00000000
            2022-06-12 10:00:14 [debug] Register 0x05 value 0x0000000e
            2022-06-12 10:00:14 [debug] Register 0x06 value 0x21000040
            2022-06-12 10:00:14 [debug] Register 0x07 value 0x0000000e
            2022-06-12 10:00:15 [debug] Register 0x08 value 0x00000000
            2022-06-12 10:00:15 [debug] Register 0x09 value 0x00000000
            2022-06-12 10:00:15 [debug] Register 0x0a value 0x00000000
            2022-06-12 10:00:15 [info] Event logging stopped
