    heater question
    Using Duet Controllers
    • Drakundefined
      Drak
      I have been testing this hotend i made myself, controlling it with a duet wifi. I am able to heat it up now but it heats up at a low rate. ( i can get to a temp of around 205 but it takes a while). I thought running M303, tuning, would help with that but i recieve this error when i do the tuning.
      I explained the hot end heater in this other post i made
      since that post i have found more permanent positions for the temp sensors and securing them with screws.
      https://forum.duet3d.com/topic/28622/heater-code-setup-question/15?_=1655061706238
        How long does it take to get to 205?
        Have you tried tuning to a lower temperature?
        I think you still have the same problem as you did in the original thread.
        Did you try bang bang mode?
        Drakundefined 2 Replies Last reply Reply Quote 0
        • Drakundefined
          Drak @Phaedrux
          @phaedrux
          it takes around 15 minutes to get to 205. band bang mode is when you turn B0 to B1 correct?
          the problem on the other thread was that it wasnt heating up at all, i found an error in my wiring, now it heats up but seems it could heat faster.
          • Drakundefined
            Drak @Phaedrux
            @phaedrux
            tuned at lower temp, seems to heat faster. how do i activate bang bang mode again?
              Yes, M307 H0 B1 for bang bang
              If you were able to tune it at a lower temp, try increasing your tune temp a bit until you get issues. Try and get it as high as possible and see how that goes.
