    Duet 2 wifi - software reset 0x4083
    Using Duet Controllers
    1.1k
    • Leonard03undefined
      Leonard03
      Hello everyone!
      Can somebody point me to the right direction what is happening?
      6/11/2022, 11:07:41 AM: M122: === Diagnostics ===
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.1 (2022-06-01 21:05:28) running on Duet WiFi 1.02 or later + DueX5
      Board ID: 08DGM-917NK-F2MS4-7JKDG-3S06M-9ZSWD
      Used output buffers: 3 of 26 (26 max)
      Static ram: 23860
      Dynamic ram: 78016 of which 12 recycled
      Never used RAM 7264, free system stack 150 words
      Tasks: NETWORK(ready,13.5%,217) HEAT(notifyWait,0.0%,333) Move(notifyWait,0.0%,304) DUEX(notifyWait,0.0%,24) MAIN(running,86.5%,466) IDLE(ready,0.0%,30), total 100.0%
      Owned mutexes: WiFi(NETWORK)
      Last reset 00:24:38 ago, cause: software
      Last software reset at 2022-06-11 10:42, reason: StuckInSpinLoop, GCodes spinning, available RAM 5992, slot 0
      Software reset code 0x4083 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80f BFAR 0xe000ed38 SP 0x200016bc Task IDLE Freestk 44 ok
      Stack: 0045cd7d 0045d722 61000000 a5a5a5a5 0045cd7d a5a5a5a5 20002334 0294282d 20002c00 20005c40 200016d4 20005c38 00000004 20001428 20001428 200016d4 00000000 00000001 20001730 4e49414d 00000000 00000000 00000001 00000001 12422a05 00000000 00000000
      Error status: 0x04
      Aux0 errors 0,0,0
      Step timer max interval 0
      MCU temperature: min 29.2, current 29.4, max 29.8
      Supply voltage: min 1.2, current 1.2, max 1.3, under voltage events: 1, over voltage events: 0, power good: no
      Heap OK, handles allocated/used 99/22, heap memory allocated/used/recyclable 2048/494/38, gc cycles 0
      Events: 0 queued, 0 completed
      Driver 0: standstill, SG min n/a
      Driver 1: standstill, SG min n/a
      Driver 2: standstill, SG min n/a
      Driver 3: standstill, SG min n/a
      Driver 4: standstill, SG min n/a
      Driver 5: standstill, SG min n/a
      Driver 6: standstill, SG min n/a
      Driver 7: standstill, SG min n/a
      Driver 8: standstill, SG min n/a
      Driver 9: standstill, SG min n/a
      Driver 10:
      Driver 11:
      Date/time: 2022-06-11 11:07:40
      Slowest loop: 4.20ms; fastest: 0.14ms
      === Storage ===
      Free file entries: 9
      SD card longest read time 0.6ms, write time 0.0ms, max retries 0
      DMs created 83, segments created 3, maxWait 0ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 4, completed 4, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
      === AuxDDARing ===
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is doing "G4 S4" in state(s) 0 0, running macro
      Code queue is empty
      === DueX ===
      Read count 0, 0.00 reads/min
      === Network ===
      Slowest loop: 202.97ms; fastest: 0.07ms
      Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
      HTTP sessions: 1 of 8
      - WiFi -
      Network state is active
      Failed messages: pending 0, notready 0, noresp 2
      WiFi firmware version 1.26
      WiFi MAC address b4:e6:2d:52:f5:47
      WiFi Vcc 3.40, reset reason Power up
      WiFi flash size 4194304, free heap 25040
      WiFi IP address 10.57.183.107
      WiFi signal strength -41dBm, mode 802.11n, reconnections 0, sleep mode modem
      Clock register 00002002
      The restart occured after ~16h of printing during a G1 H4 command form a macro.
      I've searched the stack trace in Duet2CombinedFirmware.map and the result points me in two directions:
      .bss._ZL11networkTask
      0x20002c00      0x9bc ./src/Networking/Network.o
      .bss._ZL8mainTask
      0x200016d4     0x11b4 ./src/Platform/Tasks.o
      Is the wifi module failing? It is not getting hot, just warm in operation 😑
        Can you share your config.g and the gcode file you were printing?
        Has this ever happened before? Did you attempt the file again?
          Leonard03
          Hello @Phaedrux and thank you for your replay 😊
          @phaedrux said in Duet 2 wifi - software reset 0x4083:
          Here is my config:
          ; generated by RepRapFirmware Configuration Tool v3.2.0 on Tue Dec 29 2020 16:23:44 GMT+0200 (Eastern European Standard Time)
          global useMMU = true									; enable or disable Multi Material Unit
          if global.useMMU = true
          	global useCutter = true								; enable or disable the CUT fnction of the Multi Material Unit
          	global mmuErr = 0
          	global statusBondtech = 0
          	global statusFinda = 0
          G90                                               		; send absolute coordinates...
          M83                                               		; ...but relative extruder moves
          	M550 P"Creality CR-10L MMU2S"						; set printer name
          else
          	M550 P"Creality CR-10L"
          M552 S1                                           		; enable network
          M586 P0 S1                                        		; enable HTTP
          M586 P1 S0                                        		; enable FTP
          M586 P2 S0                                        		; disable Telnet
          M569 P0 S1                                        		; physical drive 0 goes forwards
          M569 P1 S1                                        		; physical drive 1 goes forwards
          M569 P2 S0                                        		; physical drive 2 goes backwards
          M569 P3 S0                                        		; physical drive 3 goes forwards
          	M569 P5 S1
          	M569 P6 S0
          	M569 P7 S0
          M584 X0 Y1 Z2 E3:3:3:3:3                                ; set drive mapping       M584 X0 Y1 Z2 E3
          	M584 U5 V6 W7
          M350 X16 Y16 Z16 E16 I1                        			; configure microstepping with interpolation
          	M350 U16 V16 W16 I1
          M92 X80.00 Y80.00 Z400.00 E415.00          				; set steps per mm
          	M92 U400 V145 W26
          M566 X600.00 Y600.00 Z24.00 E3000.00     				; set maximum instantaneous speed changes (mm/min)
          	M566 U24 V600 W600
          M203 X18000.00 Y18000.00 Z1200.00 E6000.00				; set maximum speeds (mm/min)
          	M203 U2400 V5400 W3000
          M201 X3000.00 Y3000.00 Z100.00 E5000.00     			; set accelerations (mm/s^2)
          	M201 U500 V1500 W1500
          M201.1 X500 Y500 Z50 E1000								;Set reduced acceleration for special move types (mm/s^2)
          	M201.1 U250 V500 W500
          M906 X800 Y800 Z800 E600 I40                			; set motor currents (mA) and motor idle factor in per cent   I30
          	M906 U700 V700 W700									; M906 U800 V800 W800
          M84 S30                                           		; Set idle timeout
          M208 X0 Y0 Z0 S1                                  		; set axis minima
          	M208 U0 V-1000 W0 S1
          M208 X315 Y311 Z400 S0                            		; set axis maxima
          	M208 U75 V1000 W78 S0
          M574 X1 S1 P"^xstop"                               		; configure active-high endstop for low end on X via pin xstop
          M574 Y1 S1 P"^ystop"                               		; configure active-high endstop for low end on Y via pin ystop
          M574 Z1 S1 P"^zstop"                               		; configure active-high endstop for low end on Z via pin zstop
          	M574 U2 S3
          	M574 V0
          	M574 W1 S3
          M950 S0 C"!exp.heater7"                            		; create servo pin 0 for BLTouch
          M558 P9 C"^zprobe.in" H5 F120 T6000 A20 S0.005    		; set Z probe type to bltouch and the dive height + speeds
          G31 P500 X-27.4 Y-28.6 Z2.00                     		; set Z probe trigger value, offset and trigger height
          M557 X8.0:287.6 Y21.6:271.6 P5                         	; define mesh grid
          M308 S0 P"bedtemp" Y"thermistor" T100000 B4092    		; configure sensor 0 as thermistor on pin bedtemp
          M950 H0 C"bedheat" T0                            		; create bed heater output on bedheat and map it to sensor 0
          M307 H0 B1 S1.00                                  		; enable bang-bang mode for the bed heater and set PWM limit
          M140 H0                                           		; map heated bed to heater 0
          M143 H0 S110                                      		; set temperature limit for heater 0 to 110C
          M308 S1 P"spi.cs1" Y"rtd-max31865"                		; configure sensor 1 as thermocouple via CS pin spi.cs1
          M950 H1 C"e0heat" T1                              		; create nozzle heater output on e0heat and map it to sensor 1
          M307 H1 B0 S1.00                                  		; disable bang-bang mode for heater  and set PWM limit
          M143 H1 S400                                      		; set temperature limit for heater 1 to 400C
          M950 F0 C"fan0" Q10000                            		; create fan 0 on pin fan0 and set its frequency
          M106 P0 S0 H-1 L0.3 C"Tool"                       		; set fan 0 value. Thermostatic control is turned off
          M950 F1 C"fan1+^exp.pb6" Q25000                   		; create fan 1 on pin fan1 and set its frequency
          M106 P1 S1 H1 T45 C"Heatsink"                           ; set fan 1 value. Thermostatic control is turned on
          M563 P0 D0 H1 F0                                  		; define tool 0
          G10 P0 X0 Y0 Z0                                   		; set tool 0 axis offsets
          M568 P0 R0 S0 A0                                      	; set initial tool 0 active and standby temperatures to 0C
          	M563 P1 D1 H1 F0                                  	; define tool 1
          	G10 P1 X0 Y0 Z0                                   	; set tool 1 axis offsets
          	M568 P1 R0 S0 A0                                    ; set initial tool 1 active and standby temperatures to 0C
          	M563 P2 D2 H1 F0                                  	; define tool 2
          	G10 P2 X0 Y0 Z0                                   	; set tool 2 axis offsets
          	M568 P2 R0 S0 A0                                    ; set initial tool 2 active and standby temperatures to 0C
          	M563 P3 D3 H1 F0                                  	; define tool 3
          	G10 P3 X0 4Y0 Z0                                   	; set tool 3 axis offsets
          	M568 P3 R0 S0 A0                                    ; set initial tool 3 active and standby temperatures to 0C
          	M563 P4 D4 H1 F0                                  	; define tool 4
          	G10 P4 X0 Y0 Z0                                   	; set tool 4 axis offsets
          	M568 P4 R0 S0 A0									; set initial tool 4 active and standby temperatures to 0C
          ; Custom settings
          M81 C"pson"												; ATX in stadby mode at boot
          M308 S2 Y"mcu-temp" A"MCU"						  		; MCU temperature sensor (sensor 2)
          M308 S3 Y"drivers" A"TMC Drivers"				  		; drivers temperature sensors (sensor 3)
          M912 P0 S-7.2									  		; set temperature monitor adjustment (MCU)
          M307 H0 R0.135 C783.5 D0.39 S1.00 V12.2			  		; set the process parameters (bed 60degC)
          M307 H1 R1.757 K0.275:0.139 D6.31 E1.35 S1.00 B0 V12.2	; set the process parameters (hotend 210degC)
          M207 S0.8 F1800											; set retract length (PLA)
          M404 N1.75												; set filament width
          if global.useMMU = false
          	M591 D0 P1 C"^e0stop" S0		  						; filament monitor connected to E0 endstop (Drive 0)
          M950 J1 C"^e1stop" 							 			; Input 1 uses e2stop pin, pullup enabled (EmergencyStop button)
          M581 P1 T0 S1 R0 								  		; external trigger 1, trigger occurs on the active-to-inactive edge, trigger at any time
          M950 J2 C"^duex.e3stop" 							 	; Input 1 uses e2stop pin, pullup enabled (power feedback for UPS)
          M581 P2 T2 S1 R1 								  		; external trigger 1, trigger occurs on the inactive-to-active edge, trigger at any time (UPS Backup power)
          M581 P2 T3 S0 R2 								  		; external trigger 1, trigger occurs on the active-to-inactive edge, trigger only when not printing from SD card (AC back, resume prompt)
          M593 P"ZVD" F30.2										; use ZVD input shaping to cancel ringing at 30.0Hz
          M204 P600 T800											; set printing and travel accelerations (mm/s^2)
          ;M204 P1500 T2000
          M671 X30:30:275:275 Y30:275:275:30 P0.7	F5.0			; adjusting screws at front left (30,30), back left (30,275), back right (275,275) and front right (275,30). Thread pitch M4 corse: 0.7mm
          	M98 P"0:/sys/MMU Control/settingsPrinter.g"
          	M98 P"0:/sys/MMU Control/settingsDefaultFilament.g"
          M575 P1 S1 B57600                                 		; enable support for PanelDue
          M501                                           	  		; load saved parameters from non-volatile memory
          I think that my config will not make too much sense without the context so i'll leave you a backup of my SD card, just because my issues occurs during tool changes:
          https://drive.google.com/drive/folders/1OcTPiUw0RlYuLT-Skopb6It37nG4u9Io?usp=sharing
          Unfortunately the gcode that failes is too big to upload it here, but you can find it in the google drive, gcodes folder.
          Actually yes, many times, different gcodes, never twice at the same point but some worked flawlessly and many more failed (M122 report).
          Let's say I got 5 prints done ok and >20 prints failed.
          PS, with the network adapter disabled, works better..
          I'm sure that last time then RRF crashed it was here:
          \sys\MMU Control\loadToFinda.g
          but I can't say for sure which line was executing 😢
          Thank you again 😊
            Leonard03
            Well.. I have an update:
            Just finished a print. 16h and 38min.. and work flawlessly, not a single DWC drop during this time, but the diagnostics changed a little bit:
            m122
            Static ram: 23860
            Dynamic ram: 78984 of which 256 recycled
            Never used RAM 5260, free system stack 96 words
            Tasks: NETWORK(ready,3.6%,143) HEAT(notifyWait,0.4%,308) Move(notifyWait,6.5%,284) DUEX(notifyWait,0.0%,24) MAIN(running,89.3%,421) IDLE(ready,0.2%,30), total 100.0%
            Owned mutexes:
            Last reset 23:19:41 ago, cause: software
            Last software reset at 2022-06-14 12:11, reason: User, GCodes spinning, available RAM 7432, slot 0
            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
            Error status: 0x0c
            Aux0 errors 0,2,0
            MCU temperature: min 26.8, current 28.6, max 30.1
            Supply voltage: min 1.2, current 1.3, max 12.4, under voltage events: 1, over voltage events: 0, power good: no
            Heap OK, handles allocated/used 99/22, heap memory allocated/used/recyclable 2048/514/58, gc cycles 25
            Driver 0: standstill, SG min 0
            Driver 1: standstill, SG min 0
            Driver 2: standstill, SG min 0
            Driver 3: standstill, SG min 0
            Driver 5: standstill, SG min 0
            Driver 6: standstill, SG min 0
            Driver 7: standstill, SG min 0
            Driver 10:
            Driver 11:
            Date/time: 2022-06-15 11:31:17
            Slowest loop: 137.69ms; fastest: 0.10ms
            === Storage ===
            SD card longest read time 44.6ms, write time 0.6ms, max retries 0
            DMs created 83, segments created 36, maxWait 7041682ms, bed compensation in use: mesh, comp offset -0.005
            === MainDDARing ===
            Scheduled moves 475212, completed 475212, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 2], CDDA state -1
            === AuxDDARing ===
            Segments left: 0
            Code queue is empty
            === DueX ===
            Read count 1489, 2.45 reads/min
            === Network ===
            Slowest loop: 199.87ms; fastest: 0.07ms
            - WiFi -
            Failed messages: pending 0, notready 0, noresp 24
            WiFi signal strength -35dBm, mode 802.11n, reconnections 0, sleep mode modem
            And during the print PanelDue catched this: 20220615_002454.jpg
            A single note: Before starting this print, a reflashed the WiFi module (M997 S1) and that was it.
            Now, this rised two questions in my head:
            • Can the WiFi module firmware get corrupted during normal operation?
            • If so.. there will be any early symptoms in this regard?
              dc42 administrators @Leonard03
              @leonard03 the error code along with the fact that the IDLE task was running (which is very usual) indicates that neither the main task nor the network task could run. This is very unusual and should only happen for very brief periods, nowhere near long enough to get the "Stuck in spin loop" reset. It could possibly be caused by a firmware bug (i.e. deadlock), but as nobody else has reported this type of reset, I suspect it was caused by memory corruption, possibly caused by ESD. Please ground the hot end metalwork and the extruder body (if separate) or extruder motor body if you have not already done so. We know that extruding filament causes static charge to build up in some circumstances and this charge flashes over to the thermistor connections.
              The "slowing down poll rate" message from PanelDue means that PanelDue was seeing too many missed replies from the Duet, so it reduced the poll rate to lessen the load on the Duet.
              It's not impossible that the WiFi module firmware could get corrupted, for example by ESD or by a transient on the +3.3V supply. We don't yet do a CRC check on the WiFi firmware as we do on the main board firmware.
                Leonard03
                Wow thank you very much @dc42, is an honor to receive an answer from you 😊
                Up to this point, all problems was is this order:
                • First print, DWC reconnected every couple of seconds. I solved this by increasing the the number of AJAX retries from 1 (I don't know if this was the default) to 20 (why not).
                • After this, 3.4.1-rc2 was released, and the increased number of output buffers for the Duet 2 WiFi made a big difference, but still had issues.
                • Reviewing my config (based from 2.05?) I activated the pullup resistors on all endstops (all being endstops with only two wires). Again, another step in the right direction.
                From there on, everything seems to be good so far, at least until I started this topic.
                I will try your suggestion about grounding the steppers (at this moment all 8 steppers are isolated - because they are mounted by plastic mounts) and I will post an update
                Thank you again for your time analyzing my problem 😊
                • Leonard03undefined Leonard03 marked this topic as a regular topic
                  Leonard03
                  Hello @dc42 !
                  Unfortunately grounding the steppers didn't have any effect to this issue 😕
                  Print stopped last night after around 9h with the same error code and the same reason "stuckinspinloop"...
                    That's too bad. Did you also have the hot end metal grounded? Is the frame itself grounded?
                      Leonard03
                      Good morning 😊
                      @Phaedrux do you belive in ghosts? Because this thing is hunted by something 👻
                      Leaving all jokes aside:
                      I completed a 12:30 hours print last night without touching any wire of the printer. What changed are two things:
                      Yesterday PrusaSlicer 2.5.0-alpha2 was released on github and I give it a try.
                      Second, my WiFi Router has received a firmware upgrade (also yesterday) but the change log says only this:
                      Modifications and Bug Fixes:
                      1. Updating cloud Services.
                      2. Enhance device security.
                      And my test looks like this
                      Any Ideas? It started to become very annoying 😑
                        Leonard03
                        Well, failed again after 7 hours
                        Static ram: 23860
                        Dynamic ram: 77920 of which 12 recycled
                        Never used RAM 7360, free system stack 144 words
                        Tasks: NETWORK(ready,12.4%,257) HEAT(notifyWait,0.0%,333) Move(notifyWait,0.0%,306) DUEX(notifyWait,0.0%,24) MAIN(running,87.5%,466) IDLE(ready,0.0%,30), total 100.0%
                        Last reset 00:36:27 ago, cause: software
                        Last software reset at 2022-07-01 20:34, reason: StuckInSpinLoop, GCodes spinning, available RAM 6064, slot 0
                        Software reset code 0x4083 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041a80f BFAR 0xe000ed38 SP 0x200016bc Task IDLE Freestk 44 ok
                        Stack: 0045cd7d 0045d728 61000000 a5a5a5a5 0045cd7d a5a5a5a5 2000232c 01ba8527 20002c00 20005c40 200016d4 20005c38 00000004 20001428 20001428 200016d4 00000000 00000001 20001730 4e49414d 00000000 00000000 00000001 00000001 cdd7a346 00000000 00000000
                        Error status: 0x04
                        Aux0 errors 0,0,0
                        MCU temperature: min 31.7, current 33.7, max 35.8
                        Supply voltage: min 0.4, current 1.2, max 12.9, under voltage events: 1, over voltage events: 0, power good: no
                        Heap OK, handles allocated/used 99/22, heap memory allocated/used/recyclable 2048/456/0, gc cycles 0
                        Driver 10:
                        Driver 11:
                        Date/time: 2022-07-01 21:11:00
                        Slowest loop: 10.99ms; fastest: 0.14ms
                        === Storage ===
                        Free file entries: 10
                        SD card longest read time 4.5ms, write time 0.0ms, max retries 0
                        DMs created 83, segments created 3, maxWait 306097ms, bed compensation in use: none, comp offset 0.000
                        === MainDDARing ===
                        Scheduled moves 1, completed 1, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state -1
                        === AuxDDARing ===
                        Segments left: 0
                        Daemon is idle in state(s) 0
                        Code queue is empty
                        === DueX ===
                        Read count 7, 0.19 reads/min
                        === Network ===
                        Slowest loop: 15.51ms; fastest: 0.00ms
                        - WiFi -
                        WiFi flash size 4194304, free heap 24640
                        WiFi signal strength -40dBm, mode 802.11n, reconnections 0, sleep mode modem
                        Socket states: 4 0 0 0 0 0 0 0
                        But the diagnostics report during printing is pretty interesting:
                        M122
                        RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.1 (2022-06-01 21:05:28) running on Duet WiFi 1.02 or later + DueX5v0.11
                        Used output buffers: 6 of 26 (26 max)
                        Static ram: 23860
                        Dynamic ram: 78568 of which 12 recycled
                        Never used RAM 6064, free system stack 106 words
                        Tasks: NETWORK(ready,218.0%,215) HEAT(notifyWait,0.9%,324) Move(notifyWait,9.9%,282) DUEX(notifyWait,0.0%,24) MAIN(running,288.6%,421) IDLE(ready,0.4%,30), total 517.8%
                        Last reset 05:23:41 ago, cause: power up
                        Last software reset at 2022-06-23 21:17, reason: StuckInSpinLoop, GCodes spinning, available RAM 6040, slot 2
                        Stack: 0045cd7d 0045d72c 61000000 a5a5a5a5 0045cd7d a5a5a5a5 20002334 020046da 20002c00 20005c40 200016d4 20005c38 00000004 20001428 20001428 200016d4 00000000 00000001 20001730 4e49414d 00000000 00000000 00000001 00000001 4984a1d4 00000000 00000000
                        Error status: 0x0c
                        Aux0 errors 0,1,0
                        MCU temperature: min 21.0, current 34.0, max 34.3
                        Supply voltage: min 0.0, current 12.2, max 12.9, under voltage events: 0, over voltage events: 0, power good: yes
                        Heap OK, handles allocated/used 99/23, heap memory allocated/used/recyclable 2048/1670/1188, gc cycles 7
                        Driver 3: ok, SG min 0
                        Driver 10:
                        Driver 11:
                        Date/time: 2022-07-01 17:54:52
                        Slowest loop: 131.43ms; fastest: 0.11ms
                        === Storage ===
                        SD card longest read time 6.5ms, write time 11.9ms, max retries 0
                        DMs created 83, segments created 30, maxWait 2411303ms, bed compensation in use: mesh, comp offset -0.010
                        === MainDDARing ===
                        Scheduled moves 26975, completed 26974, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state 3
                        === AuxDDARing ===
                        Heater 0 is on, I-accum = 0.0
                        Heater 1 is on, I-accum = 0.4
                        Segments left: 0
                        Movement lock held by File
                        File is idle in state(s) 19
                        Code queue is empty
                        === Filament sensors ===
                        Extruder 0 sensor: ok
                        === DueX ===
                        Read count 1094, 3.38 reads/min
                        === Network ===
                        Slowest loop: 31.81ms; fastest: 0.00ms
                        - WiFi -
                        WiFi Vcc 3.40, reset reason Turned on by main processor
                        WiFi flash size 4194304, free heap 26240
                        WiFi signal strength -37dBm, mode 802.11n, reconnections 0, sleep mode modem
                        Socket states: 0 2 0 0 0 0 0 0
                        Please have a look at tasks percentages
                          Leonard03
                          I've tried something today. I've left the printer on all day without turning on the main PSU and issued two M122 commands:
                          7/5/2022, 7:04:56 PM: Connected to 10.57.183.107
                          7/5/2022, 7:05:11 PM: m122: === Diagnostics ===
                          Static ram: 23860
                          Never used RAM 7432, free system stack 190 words
                          Tasks: NETWORK(ready,149.2%,217) HEAT(notifyWait,0.4%,333) Move(notifyWait,0.0%,363) DUEX(notifyWait,0.0%,24) MAIN(running,329.6%,462) IDLE(ready,0.1%,30), total 479.2%
                          Last reset 04:09:43 ago, cause: software
                          Last software reset at 2022-07-04 23:32, reason: User, GCodes spinning, available RAM 7412, slot 0
                          Error status: 0x04
                          Aux0 errors 0,0,0
                          MCU temperature: min 31.9, current 33.5, max 33.9
                          Supply voltage: min 1.2, current 1.3, max 1.4, under voltage events: 0, over voltage events: 0, power good: no
                          Driver 0: ok, SG min n/a
                          Driver 1: ok, SG min n/a
                          Driver 2: ok, SG min n/a
                          Driver 3: ok, SG min n/a
                          Driver 4: ok, SG min n/a
                          Driver 5: ok, SG min n/a
                          Driver 6: ok, SG min n/a
                          Driver 7: ok, SG min n/a
                          Driver 8: ok, SG min n/a
                          Driver 9: ok, SG min n/a
                          Driver 10:
                          Driver 11:
                          Date/time: 2022-07-05 19:05:20
                          Slowest loop: 16.61ms; fastest: 0.14ms
                          === Storage ===
                          SD card longest read time 4.9ms, write time 1.2ms, max retries 0
                          DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                          === MainDDARing ===
                          === AuxDDARing ===
                          Segments left: 0
                          Code queue is empty
                          === DueX ===
                          === Network ===
                          Slowest loop: 200.76ms; fastest: 0.07ms
                          - WiFi -
                          Failed messages: pending 0, notready 0, noresp 1
                          WiFi flash size 4194304, free heap 24952
                          7/5/2022, 8:24:36 PM: M122: === Diagnostics ===
                          Static ram: 23860
                          Tasks: NETWORK(ready,337.3%,217) HEAT(notifyWait,0.9%,333) Move(notifyWait,0.1%,363) DUEX(notifyWait,0.0%,24) MAIN(running,2417.5%,462) IDLE(ready,0.1%,30), total 2755.8%
                          Owned mutexes:
                          Last reset 05:28:57 ago, cause: software
                          Error status: 0x04
                          Aux0 errors 0,0,0
                          MCU temperature: min 33.0, current 33.6, max 34.2
                          Driver 10:
                          Driver 11:
                          Date/time: 2022-07-05 20:24:34
                          Slowest loop: 7.37ms; fastest: 0.14ms
                          === Storage ===
                          SD card longest read time 1.0ms, write time 0.0ms, max retries 0
                          === MainDDARing ===
                          === AuxDDARing ===
                          Segments left: 0
                          Code queue is empty
                          === DueX ===
                          === Network ===
                          Slowest loop: 201.77ms; fastest: 0.07ms
                          Responder states: HTTP(2) HTTP(2) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
                          - WiFi -
                          WiFSocket states: 4 2 0 0 0 0 0 0
                          @dc42 do these percentages look ok?
                          Looks like those report matches the issues seen in the stacktrace
                            Leonard03
                            So I tried grounding my hotend as @dc42 suggested.
                            It is an E3D V6 Gold edition with a titanium heatbreak and the nozzleX.
                            Last night I've seen this https://forum.duet3d.com/topic/28399/1lc-board-stopped-working-but-still-responsive-to-m122/12 and now I give it a try but turns out that the heatsink is electrically isolated. Only the heatblock is conductive. Now what ?!
                            And as a thought - how this board was very stable before RRF3, with a configuration with two extruders and two bowden tubes about 700mm long and can print that took days to complete without any problems ?
                              Sorry for leaving you hanging. I'll mention it to DC42 again.
                              Just to confirm, you're still getting software reset 0x4083?
                                Leonard03
                                Hello @Phaedrux and welcome back 😊
                                Please hold on until tomorrow..
                                I'll start another test with the new released 3.4.2rc1 and I'll post an update
                                Thankyou very much for your time and patience 😁
                                  Leonard03
                                  Correction - worked only for 3 hours and failed with the same reason.. 4083
                                  RRF crashed 2 minutes ago with this report
                                  RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.2rc1 (2022-07-06 16:21:02) running on Duet WiFi 1.02 or later + DueX5
                                  Static ram: 23860
                                  Dynamic ram: 77968 of which 0 recycled
                                  Never used RAM 7324, free system stack 148 words
                                  Tasks: NETWORK(ready,12.4%,254) HEAT(notifyWait,0.0%,333) Move(notifyWait,0.0%,304) DUEX(notifyWait,0.0%,24) MAIN(running,86.7%,456) IDLE(ready,0.8%,30), total 100.0%
                                  Last reset 00:01:33 ago, cause: software
                                  Last software reset at 2022-07-08 00:43, reason: StuckInSpinLoop, GCodes spinning, available RAM 5820, slot 2
                                  Stack: 0045cdcd 0045d77a 61000000 a5a5a5a5 0045cdcd a5a5a5a5 2000232c 00c47889 20002c00 20005c40 200016d4 20005c38 00000004 20001428 20001428 200016d4 00000000 00000001 20001730 4e49414d 00000000 00000000 00000001 00000001 809f72da 00000000 00000000
                                  Error status: 0x04
                                  Aux0 errors 0,0,0
                                  MCU temperature: min 28.5, current 29.7, max 30.1
                                  Supply voltage: min 0.6, current 12.3, max 13.0, under voltage events: 0, over voltage events: 0, power good: yes
                                  Driver 10:
                                  Driver 11:
                                  Date/time: 2022-07-08 00:45:05
                                  Cache data hit count 3472812724
                                  Slowest loop: 10.69ms; fastest: 0.13ms
                                  === Storage ===
                                  SD card longest read time 0.8ms, write time 0.0ms, max retries 0
                                  DMs created 83, segments created 3, maxWait 53873ms, bed compensation in use: none, comp offset 0.000
                                  === MainDDARing ===
                                  === AuxDDARing ===
                                  Segments left: 0
                                  Code queue is empty
                                  === DueX ===
                                  Read count 4, 2.56 reads/min
                                  === Network ===
                                  Slowest loop: 15.52ms; fastest: 0.00ms
                                  - WiFi -
                                  WiFi flash size 4194304, free heap 26928
                                  And by the way, my only chance to ground the nozzle (for the E3D V6 Gold at least) is to ground the heaterblock directly.. 🤕
                                    Can you ground the stepper at least? If the source of the ESD is from the filament then the contact with the drive gear and motor shaft may mean grounding the stepper is enough.
                                      Leonard03
                                      Actually the extruder motor is already grounded 😁
                                      But the funny thing is that the filament don't even touch the extruder when the board restarts 🙃
                                      Last 4 or 5 attempts to print the same model the crash happening always before the tip of the filament reaching the extruder so the second endstop. Never happend during printing, seems to be always during execution of "loadToBondtech.g" right above the extruder gears...
                                        Leonard03
                                        Ah, and as a side note:
                                        As I seen this idea also somewhere here on the forum, I tried to simulate that gcode and the simulation completed without warnings or errors
