    New issue after upgrading firmware to 3.4.1
    My Duet controlled machine
    • bramerrfundefined
      bramerrf
      Historically at the end of each print the extruder and bed heaters were automatically switch off. After upgrading to 3.4.1 I noticed that when a print finished the extruder and bed heaters remained active.
      Previously my ending script finished with "M0" now that has no discernable effect. I tried replacing with "M104 S0" and "M140 S0" but they had no effect either.
      I must be doing something incorrectly, any advice will be much appreciated.
      Stephen6309undefined dc42undefined 2 Replies Last reply Reply Quote 0
      • Stephen6309undefined
        Stephen6309 @bramerrf
        @bramerrf Put them in stop.g, which is called by M0.
        For example, I use this in stop.g
        ; stop.g
        ; called when M0 (Stop) is run (e.g. when a print from SD card is cancelled)
        M591 D0 S0 	; turn off filament monitor
        M98 P"/macros/EnableHoming"
        M568 P0 A0		; turn off hotend
        M140 H0 S-274	; turn off bed
        M107			; turn off parts fan
        G90				; absolute positioning
        M84				; turn off motors
        bramerrfundefined 1 Reply Last reply Reply Quote 0
          dc42 administrators @bramerrf
          @bramerrf if you have a stop.g file then with RRF 3.4.0 and later you need to turn those heaters off explicitly in that file.
          • bramerrfundefined
            bramerrf @Stephen6309
            @stephen6309 said in New issue after upgrading firmware to 3.4.1:
            Thanks for all the replies.
            I will try to put everything I want into stop.g and see how few mistakes I make.
            Thanks again.
