    Change in behaviour after 3.4.1 upgrade
    My Duet controlled machine
    • bramerrfundefined
      bramerrf
      Previously I was using RRF2.x and when a print was completed and new one was to be started it was not necessary to run"home all" or "bed levelling" again. After upgrading to RRF3.4.1 and adding a stop.g file after each print before I can start a new one I now have to run 'home all' and 'compensation & calibration'.
      It is very likely something I have done or not done something that is the issue. Can anyone advise on how I can hold onto the home all and bed level status at the end of a print so that a new on be started immediately?
      config.g and stop.g below:-
      ; Configuration file for Duet WiFi / Ethernet running RRF3 on E3D Tool Changer
      ;modified Thursday June 9th 2022
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      M667 S1 ; Select CoreXY mode
      M550 P"ImpTC" ; Set machine name
      ;M587 S"ssid" P"password" ; WiFi Settings
      ;M552 S1 P"ssid" ; Enable WiFi Networking
      M552 S1 ; Enable Networking
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      ; Drive direction
      M569 P0 S0 ; Drive 0 X
      M569 P1 S0 ; Drive 1 Y
      M569 P2 S1 ; Drive 2 Z
      M569 P3 S0 ; Drive 3 E0
      M569 P4 S0 ; Drive 4 E1
      M569 P5 S1 ; Drive 5 E2
      M569 P6 S1 ; Drive 6 E3
      M569 P7 S0 ; Drive 7 COUPLER
      M569 P8 S0 ; Drive 8 UNUSED
      M569 P9 S0 ; Drive 9 UNUSED
      M584 X0 Y1 Z2 C7 E3:4:5:6 ; Apply custom drive mapping
      M208 X-35:328.5 Y-49:243 Z0:300 C-45:360 ; Set axis maxima & minima
      M92 X100 Y100 Z1600 C91.022 E834:834:834:834 ; Set steps per mm assuming x16 microstepping
      M350 E16:16:16:16 I1 ; Configure microstepping with interpolation
      M350 C16 I10 ; Configure microstepping without interpolation
      M350 X16 Y16 Z16 I1 ; Configure microstepping with interpolation
      M566 X400 Y400 Z8 C2 E2:2:2:2 ; Set maximum instantaneous speed changes (mm/min)
      M203 X35000 Y35000 Z1200 C5000 E5000:5000:5000:5000 ; Set maximum speeds (mm/min)
      M201 X6000 Y6000 Z400 C500 E2500:2500:2500:2500 ; Set accelerations (mm/s^2)
      M906 X1800 Y1800 Z1330 I30 ; Idle motion motors to 30%
      M906 E1000:1000:1000:1000 C500 I10 ; Idle extruder motors to 10%
      M574 X1 Y1 S3 ; Set X / Y endstop stall detection
      M574 C0 Z0 ; No C Z endstop
      ; Z probe
      M558 P8 C"zstop" H3 F360 I0 T20000 ; Set Z probe type to switch, the axes for which it is used and the dive height + speeds
      G31 P200 X0 Y0 Z0 ; Set Z probe trigger value, offset and trigger height
      M557 X10:290 Y20:180 S40 ; Define mesh grid
      ;Stall Detection
      M915 X Y S3 F0 H400 R4700 ; X / Y Axes
      M308 S0 P"bedtemp" Y"thermistor" A"Bed" T100000 B4138 C0 ; Set thermistor
      M950 H0 C"bedheat" T0 ; Bed heater
      M143 H0 S225 ; Set temperature limit for heater 0 to 225C
      M140 H0 ; Bed heater is heater 0
      M308 S1 P"spi.cs1" Y"rtd-max31865" ; Set PT100
      M950 H1 C"e0heat" T1 ; Extruder 0 heater
      M143 H1 S305 ; Set temperature limit for heater 1 to 305C
      M308 S2 P"spi.cs2" Y"rtd-max31865" ; Set PT100
      M950 H2 C"e1heat" T2 ; Extruder 0 heater
      M143 H2 S305 ; Set temperature limit for heater 2 to 305C
      M308 S3 P"duex.cs5" Y"rtd-max31865" ; Set PT100
      M950 H3 C"duex.e2heat" T3 ; Extruder 0 heater
      M143 H3 S305 ; Set temperature limit for heater 3 to 305C
      M308 S4 P"duex.cs6" Y"rtd-max31865" ; Set PT100
      M950 H4 C"duex.e3heat" T4 ; Extruder 0 heater
      M143 H4 S305 ; Set temperature limit for heater 4 to 305C
      M563 P0 S"T0" D0 H1 F2 ; Define tool 0
      G10 P0 X0 Y0 Z0 ; Reset tool 0 axis offsets
      G10 P0 R0 S0 ; Reset initial tool 0 active and standby temperatures to 0C
      M563 P1 S"T1" D1 H2 F4 ; Define tool 1
      G10 P1 X0 Y0 Z0 ; Reset tool 1 axis offsets
      G10 P1 R0 S0 ; Reset initial tool 1 active and standby temperatures to 0C
      M563 P2 S"T2" D2 H3 F6 ; Define tool 2
      G10 P2 X0 Y0 Z0 ; Reset tool 2 axis offsets
      G10 P2 R0 S0 ; Reset initial tool 2 active and standby temperatures to 0C
      M563 P3 S"T3" D3 H4 F8 ; Define tool 3
      G10 P3 X0 Y0 Z0 ; Reset tool 3 axis offsets
      G10 P3 R0 S0 ; Reset initial tool 3 active and standby temperatures to 0C
      M950 F1 C"fan1"
      M950 F2 C"fan2"
      M950 F3 C"duex.fan3"
      M950 F4 C"duex.fan4"
      M950 F5 C"duex.fan5"
      M950 F6 C"duex.fan6"
      M950 F7 C"duex.fan7"
      M950 F8 C"duex.fan8"
      M106 P1 S255 H1 T70 ; T0 HE
      M106 P2 S0 ; T0 PCF
      M106 P3 S255 H2 T70 ; T1 HE
      M106 P4 S0 ; T1 PCF
      M106 P5 S255 H3 T70 ; T2 HE
      M106 P6 S0 ; T2 PCF
      M106 P7 S255 H4 T70 ; T3 HE
      M106 P8 S0 ; T3 PCF
      M593 F42.2 ; cancel ringing at 42.2Hz (https://forum.e3d-online.com/threads/accelerometer-and-resonance-measurements-of-the-motion-system.3445/)
      ;M376 H15 ; bed compensation taper
      ;tool offsets
      ; !ESTIMATED! offsets for:
      ; V6-tool: X-9 Y39 Z-5
      ; Volcano-tool: X-9 Y39 Z-13.5
      ; Hemera-tool: X20 Y43.5 Z-6
      G10 P0 X-9 Y39 Z-4.670 ; T0
      G10 P1 X-8.65 Y38.8 Z-4.950 ; T1
      G10 P2 X-9 Y39.2 Z-4.655 ; T2
      G10 P3 X-8.85 Y38.8 Z-4.673 ; T3
      ; the bigger the negative number for Z the more the nozzle lifts up off the bed
      ;M572 D0 S0.2 ; pressure advance T0
      ;M572 D1 S0.2 ; pressure advance T1
      ;M572 D2 S0.2 ; pressure advance T2
      ;M572 D3 S0.2 ; pressure advance T3
      ;M575 P1 S1 B57600 ; Enable LCD
      G29 S2 ; disable mesh
      T-1 ; deselect tools
      M501 ; load config-override.g
      ; stop.g
      ; called when M0 (Stop) is run (e.g. when a print from SD card is cancelled)
      M568 P0 A0 ;turn off T0 extruder heater
      M568 P1 A0 ;turn off T1 extruder heater
      M568 P2 A0 ;turn off T2 extruder heater
      M568 P3 A0 ;turn off T2 extruder heater
      M140 H0 S-274 ;turn off bed heater
      M84 ;turn off motors
      Phaedruxundefined bramerrfundefined 2 Replies Last reply Reply Quote 0
        Phaedrux Moderator @bramerrf
        @bramerrf said in Change in behaviour after 3.4.1 upgrade:
        Don't turn off the motors and they will stay homed.
        • bramerrfundefined
          bramerrf @bramerrf
          @bramerrf
          Many thanks. That did it.
