Solved Only two of three towers are homing
@velvia most likely the X endstop switch is not connected properly. Use M119 or the Object Model DWC plugin or the Endstops DWC plugin to test that endstop switch.
M119 gave me this:M119 Endstops - X: at max stop, Y: not stopped, Z: not stopped, Z probe: not stopped
So I'll check the connections. Just figured it worked since the light is on and responds.
Edit: that was the issue. Crimping these tiny cables and connectors are annoying
Thanks everyone for your help! I have other issues as well (hotend not heating, hotend fan always on even though it has temperature control), but will make a new thread for those I guess. -
