    E steps measuring
    Using Duet Controllers
    • rexxundefined
      rexx
      Hey Guys,
      I want to set my esteps xyz are done now and would like to know if i can or how to run E without heat on as i have DD ish hot end 3:1 i would remove the nozzle and measure out the nozzles hole to calcucate the steps could somone give the Gcode to move e without heat needed momentarily while i measure it up?
      on 6HC duet3
      • fcwiltundefined
        fcwilt @rexx
        @rexx
        Lookup command M302 - it allows you to enable extrusion when cold.
        And you also need to have a tool active. For a one tool printer the command T0 will do the job.
        And you can remove the nozzle or disconnect the extruder from the hotend.
        rexxundefined 1 Reply Last reply Reply Quote 1
        • rexxundefined
          rexx @fcwilt
          @fcwilt
          Thank you !
          Cheers from the greenback guy,
