Unexepected Head movement after 1.19 update
I have now tried to use M208 but this does not seem to work as suggested.
After startup, I manually entered:
[[gcode]] M208 S1 X-16 Y-3 Z0
Then ran X and Y homing.
The Web display says the printer is at (X,Y) = (0,0) not (-16, -3) as expected.
I also tried to put the M208 S1 in the config.g, reboot and got the same result.
Am I doing something wrong? Or did I misunderstand?
Thanks again, and so sorry to be do dumb…
Please share your homex.g, homey.g and homeall.g files. I have a feeling that you may have G92 commands in them that prevent M208 working as it should.
Indeed, the problem in the homing files.
In fact, I have now updated the following sys files:
config.g
bed.g
homex.g
homey.g
homez.g
homeall.g
I also updated my slicer pre and post print gcode in accordance with what I learned in this discussion.
The result is that all problems are solved!
I did a test print and it worked perfectly!
Thanks to everyone!
With my most sincere appreciation,
Ciao,
Bob -
