    Setting object model plugin to run on startup
    Duet Web Control
    • tristanryerparkeundefined
      tristanryerparke
      With duet3 and SBC, I an able to run plugins like btncmd on startup by editing /opt/dsf/conf/plugins.txt
      and adding the plugin ID
      However I don’t know the ID for some of the built in plugins like object model browser.
      Any input?
      Thanks,
      T
        jay_s_uk @tristanryerparke
        @tristanryerparke why not start them from the plugins section in DWC?
        tristanryerparkeundefined 1 Reply Last reply Reply Quote 0
          tristanryerparke @jay_s_uk
          @jay_s_uk
          I have found that their loading is not persistent, along with other dwc settings.
          The startup script method seems to fix this.
            @tristanryerparke then there's something wrong. What version are you running?
