    Error: Bad command: Set Velocity Limit Square Corner Velocity =5
    Duet Web Control
    1.0k
    • tylersuardundefined
      tylersuard
      I am getting this error constantly during a print, what is this? Duet 3 Mini 5+, RepRap newest version.
      • fcwiltundefined
        fcwilt @tylersuard
        @tylersuard said in Error: Bad command: Set Velocity Limit Square Corner Velocity =5:
        Post the file you are trying to print.
        tylersuardundefined 1 Reply Last reply Reply Quote 0
          tylersuard @fcwilt
          @fcwilt Fish-Fish_0.2mm_FLEX_20m.gcode
          Here it is, thank you for your help.
          • fcwiltundefined
            fcwilt @tylersuard
            That file is has many "commands" that I have never seen before.
            Check lines: 735, 736 and 760
              ; feature_gcode = ; once we start printing infill, increase square corner velocity to 10\n{if extrusion_role=="InternalInfill"}SET_VELOCITY_LIMIT SQUARE_CORNER_VELOCITY=10 {endif}\n; when we switch to other features, go back to 5\n{if extrusion_role!="InternalInfill"}SET_VELOCITY_LIMIT SQUARE_CORNER_VELOCITY=5 {endif}
              Seems like you're using a tuning script for ... klipper maybe?
                tylersuard @Phaedrux
                @phaedrux I did not add any of this. I just set up SuperSlicer, exactly as in the RatRig documentation, and this happened.
                • fcwiltundefined
                  fcwilt @tylersuard
                  What electronics does RatRig use?
                  What GCode "flavor" did it say to use?
                  • fcwiltundefined
                    fcwilt @fcwilt
                    This post is deleted!
